Place circles to all the blocks which has different block name and different attribute values on the same attribute tag
nanja_c86
nanja_c86
Here is the Lisp from @ВeekeeCZ, i am trying to modify.
Need to look for the block name "DT_TAP2PLG,DT_TAP4PLG,DT_TAP8PLG" and Attribute tag "tap_val". need to place circles for block ins point in different colours for different attribute values and finally need to show alert msg, number of circles placed for each attribute value, segregated by blockwise.
Attaching the Dwg file for better understanding.
@ВeekeeCZ Please check this, this is your program which you written on my other similar post, i am trying to modify for other blocks. its counting and placing circles but not by block name wise.
Please help.
(defun c:tap_eq ( / r e i e l a v c);
(setq r '(("DT_TAP2PLG" . ": 2port")
("DT_TAP4PLG" . ": 4port")
("DT_TAP8PLG" . ": 8port")))
(if (setq s (ssget "_X" (list '(0 . "INSERT") (cons 2 (apply 'strcat (mapcar '(lambda (x) (strcat (car x) ",")) r))) '(8 . "NS_RF CONSTRUCTION" )(cons 410 (getvar 'ctab)))))
(repeat (setq i (sslength s))
(setq e (ssname s (setq i (1- i))))
(if (not (vl-catch-all-error-p (setq v (vl-catch-all-apply 'getpropertyvalue (list e "tap_val")))))
(setq l (if (setq a (assoc v l))
(subst (append a (list e)) a l)
(cons (list v e) l))))))
(if l
(progn
(if (setq a (assoc "" l)) (setq l (subst (cons "BLANK" (cdr a)) a l)))
(setq c 0 l (vl-sort l '(lambda (u v) (> (length u) (length v)))))
(foreach v l
(setq c (1+ c))
(foreach e (cdr v)
(entmake (list '(0 . "CIRCLE") (assoc 10 (entget e)) '(8 . "circles") '(40 . 25) '(370 . 40) (cons 62 c)))))
(alert (apply 'strcat (mapcar '(lambda (x) (strcat "\n" (car x) " - " (itoa (1- (length x))) " circles placed.")) l)))))
(princ)
Thank you.
ВeekeeCZ
Post 2 dwgs, states before and after.
nanja_c86
I don't want to change anything in drawing. Need to count the number of blocks with attribute values and should show alert msg.
see the attached image for better understanding.
ВeekeeCZ
  (if (setq s (ssget "_X" (list '(0 . "INSERT") (cons 2 (apply 'strcat (mapcar '(lambda (x) (strcat (car x) ",")) r))) '(8 . "NS_RF CONSTRUCTION" ) (cons 410 (getvar 'ctab)))))
  (if l
    (progn
      (foreach v l
	(setq c (1+ c))
	(foreach e (cdr v)
      (entmakex (list '(0 . "MTEXT") '(100 . "AcDbEntity") '(100 . "AcDbMText") '(40 . 15) (cons 10 (trans (getpoint "\nPlace the text: ") 1 0))
		      (cons 1 (apply 'strcat (mapcar '(lambda (x) (strcat "\n" (car x) " - " (itoa (1- (length x))) " circles placed.")) l)))))))
  (princ)
nanja_c86
Its works same as before lisp, except places mtext in autocad. But what i need is need to segregate block wise
there are 3 different blocks with same attribute tag and value. Need to count for each block and display message separately by block wise.
Placing text is a good idea.  But for me Alert msg window is fine.
