Lisp works with AutoCAD 2023 but not with 2024
sander.van.pelt
sander.van.pelt
Hello everybody,
I use a lisp to lock and unlock all viewports. If I lock my viewports, they should turn green. When I unlock these, they turn red.
If I now use this lisp in AutoCAD 2023, there is nothing wrong and it works as expected.
When I use it now in AutoCAD 2024, the viewports turn white as soon as I lock them. When I unlock them, they turn red.
But the lisp is loaded and also added to the Startup Suite. If I load this lisp again, the problem is solved but if I open another drawing again (without closing the other drawing where I load the lisp again) I need to load the lisp again.
How is it possible that the lisp works correctly in 2023 but does not work in 2024 and I need to reload it every time.
thanks in advance for your comments
(vl-load-com)
(defun dxf (n ed) (cdr (assoc n ed)))
(defun c:vpl (/ AD COUNT ENT I PL SS TABNAME VP VPNO)
    (setq ad (vla-get-activedocument (vlax-get-acad-object)))
(COMMAND "-LAYER" "N" "Viewport" "" "")
(COMMAND "-LAYER" "U" "Viewport" "" "")
(COMMAND "-LAYER" "PLOT" "N" "Viewport" "")
(COMMAND "-LAYER" "ON" "Viewport" "")
    (vlax-for lay (vla-get-layouts ad)
        (if (/= (setq TabName (strcase (vla-get-name lay))) "MODEL") ;_ end of /=
            (progn
                (if (setq ss (ssget
                                 "X"
                                 (list (cons 0 "viewport")
                                 ) ;_ end of list
                             ) ;_ end of ssget
                    ) ;_ end of setq
                    (progn
                        (setq count (sslength ss))
                        (setq i 0)
                        (if (> count 0)
                            (progn
                                (while (< i count)
                                    (setq
                                        ent (ssname ss
                                                    i
                                            ) ;_ end of ssname
                                    ) ;_ end of setq
                                    (setq vpNo
                                             (dxf
                                                 69
                                                 (entget
                                                     ent
                                                 ) ;_ end of entget
                                             ) ;_ end of dxf
                                    ) ;_ end of setq
                                    (if (> vpNo 1)
                                        (progn
                                            (setq vp (vlax-ename->vla-object
                                                         ent
                                                     ) ;_ end of vlax-ename->vla-object
                                            ) ;_ end of setq
                                            (if (= (vla-get-clipped
                                                       vp
                                                   ) ;_ end of vla-get-clipped
                                                   :vlax-false
                                                ) ;_ end of =
                                                (progn
                                                    (vla-put-color
                                                        vp
                                                        70
                                                    ) ;_ end of vla-put-color
                                                    (vla-put-layer
                                                        vp
                                                        "Viewport"
                                                    ) ;_ end of vla-put-layer
                                                ) ;_ end of progn
                                                (progn
                                                    (setq
                                                        pl (entget
                                                               (dxf
        340
        (entget
        ent
        ) ;_ end of entget
                                                               ) ;_ end of dxf
                                                           ) ;_ end of entget
                                                    ) ;_ end of setq
                                                    ;get clip entity
                                                    (setq pl (vlax-ename->vla-object
        (dxf -1
        pl
        ) ;_ end of dxf
                                                    ) ;_ end of setq
                                                    (vla-put-color
                                                        pl
                                                        70
                                                    (vla-put-layer
                                                        pl
                                                        "Viewport"
                                                    (vla-put-color
                                                        vp
                                                        70
                                                    (vla-put-layer
                                                        vp
                                                        "Viewport"
                                                ) ;_ end of progn
                                            ) ;_ end of if
                                            (vla-put-displaylocked
                                                vp
                                                :vlax-true
                                            ) ;_ end of vla-put-displaylocked
                                            (vla-update vp)
                                        ) ;_ end of progn
                                    ) ;_ end of if
                                    (setq i (1+ i))
                                ) ;_ end of while
                            ) ;_ end of progn
                        ) ;_ end of if
                    ) ;_ end of progn
                ) ;_ end of if
            ) ;_ end of progn
        ) ;_ end of if
    ) ;_ end of vlax-for
) ;_ end of defun
(defun c:vpu (/ AD COUNT ENT I PL SS TABNAME VP VPNO)
            (progn
                (if (setq ss (ssget
                                 "X"
                                 ) ;_ end of list
                             ) ;_ end of ssget
                    ) ;_ end of setq
                    (progn
                        (setq i 0)
                        (if (> count 0)
                            (progn
                                (while (< i count)
                                    (setq
                                        ent (ssname ss
                                                    i
                                            ) ;_ end of ssname
                                    ) ;_ end of setq
                                    (setq vpNo
                                             (dxf
                                                 69
                                                 (entget
                                                     ent
                                                 ) ;_ end of entget
                                             ) ;_ end of dxf
                                    ) ;_ end of setq
                                    (if (> vpNo 1)
                                        (progn
                                                         ent
                                            ) ;_ end of setq
                                                       vp
                                                   :vlax-false
                                                ) ;_ end of =
                                                (progn
                                                    (vla-put-color
                                                        vp
                                                        1
                                        ; 3 green
                                                    (vla-put-layer
                                                        vp
                                                        "Viewport"
                                                ) ;_ end of progn
                                                (progn
                                                    (setq
                                                        pl (entget
                                                               (dxf
        340
        (entget
        ent
        ) ;_ end of entget
                                                               ) ;_ end of dxf
                                                           ) ;_ end of entget
                                                    ) ;_ end of setq
                                                    ;get clip entity
        (dxf -1
        pl
        ) ;_ end of dxf
                                                    ) ;_ end of setq
                                                    (vla-put-color
                                                        pl
                                                        1
                                                    (vla-put-layer
                                                        pl
                                                        "Viewport"
                                                    (vla-put-color
                                                        vp
                                                        1
                                        ; 3 green
                                                    (vla-put-layer
                                                        vp
                                                        "Viewport"
                                                ) ;_ end of progn
                                            ) ;_ end of if
                                                vp
                                                :vlax-false
                                            (vla-update vp)
                                        ) ;_ end of progn
                                    ) ;_ end of if
                                    (setq i (1+ i))
                                ) ;_ end of while
                            ) ;_ end of progn
                        ) ;_ end of if
                    ) ;_ end of progn
                ) ;_ end of if
            ) ;_ end of progn
        ) ;_ end of if
rgrainer
Try
ACADLSPASDOC set to 1
Kent1Cooper
ACADLSPASDOC is only applicable if you use a file called acad.lsp [or acadlt.lsp] to load the routine.  I would use acaddoc.lsp to do it, because you don't need to set anything to have it always run with every opening of every drawing [or creation of a new one].
The Startup Suite is >described< as being "loaded each time you start the product."  It does not say things in it are loaded every time you open a drawing.  I have sometimes had reason to think they really are, or maybe some things could be, but that may have been only under special circumstances, and a literal reading suggests they are not, so I don't use that.
This is from the page >About Auto-Loading and Running AutoLisp Routines< sounding just like the description about the Startup Suite:
By default, the acad.lsp or acadlt.lsp file is loaded only once, when the product starts, whereas the acaddoc.lsp or acadltdoc.lsp file is loaded with each individual document (or drawing).
Kent Cooper, AIA
pendean
Community Legend
Community Legend
@sander.van.pelt  Your posted LISP works fine in R2024.1 as it does in R2023.1.4 here in Win10Pro.
You might have an older VPL/VPU lisp loading and doing what you see until such time as you load this posted LISP.
Explore this page, and read carefully the words used
http://www.lee-mac.com/autoloading.html
vs
Sea-Haven
I ahve been using the startup suite for years multiple users and as far as I can tell loads for every dwg as you open. I use custom lisps so easier to not edit Acaddoc.lsp etc. My start up lisp has numerous "Autoload" this also allows demand loading of a lisp when you type a custom command name.
