Change Dimension Def Points
DGCSCAD
DGCSCAD
Hi all,
I'm looking for a nudge in the right direction to change the 2nd def point of an existing dimension. I have the new point saved as a variable, just need the dxf code for the def point (I'm not sure which one to use) to move to it.
Thank you in advance. 🙂
AutoCad 2018 (full)
Win 11 Pro
ВeekeeCZ
Better post a sample dwg with before and after. Are your dims associative and you're planning to keep it that way?
chriscowgill7373
What I usually do in these situations is to create two identical dimensions, change one with the item I am looking for, then entget and list the data and compare the two.  The dxf code that contains the change I am expecting is the one I need.
(Defun select (/ object objent objentdata)
(Setq object (ssget)
objent (ssname object 0)
objentdata (entget objent)
It can be called using (select) at the command line
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2024 on Windows 10
DGCSCAD
I'll post a dwg if needed, but for now:
  • It doesn't need to be associative.
  • The dimension is the last entity.
  • Need to move def point/ext line 2 to new point saved as variable: (209.884 61.0101 0.0)
Does that help?
AutoCad 2018 (full)
Win 11 Pro
ВeekeeCZ
Post dwg.
Kent1Cooper
14 for linear/rotated/aligned
Some Association List Codes for defining locations within Dimensions:
10 is --
  linear: arrow point end of dimension line where it meets extension line 2
  2-line angular: end of first-picked line element
13 is -- linear or 3pt angular: defpoint 1; 2-line angular: start of second-picked line element
14 is -- linear or 3pt angular: defpoint 2; 2-line angular: end of second-picked line element
15 is angular only: start of first-picked line element, or center of arc or circle
Kent Cooper, AIA
DGCSCAD
Thank you Kent1Cooper and chriscowgill7373!
You both had what I was looking for.
Here's the code:
(defun c:Ch_Dim_Pt2 (/ object objent en3 en4 ps_dim2_ins2)
(setq ps_dim2_ins2 (list 209.884 61.0101 0.0)); Set new point
(setq object (ssget "l")); Get last entity, which is a Linear Dimension
(setq objent (ssname object 0)); Get dim entity name
(setq en3 (entget objent)); Get dim entity data
(setq en4 (subst (cons 14 ps_dim2_ins2) (assoc 14 en3) en3)); Set new defpoint 2
(entmod en4); Apply changes
(entupd objent); Update entity
AutoCad 2018 (full)
Win 11 Pro
