Extend Line
Extend Line
EnM4st3r
Extend Line
EnM4st3r
What would be the easiest way to extend a Line to a surrounding Polyline?
So its just the length that changes.
Lets say i have the Line and Polyline as ename already, so i could start like that:
(defun extendtopol (line poly /)...)
Accepted solutions (4)
hosneyalaa
ВeekeeCZ
Use the intersect method with extendboth mode to find the intersection points, then somehow change the line - possibly by entmod.
See HERE
EnM4st3r
alright, i'll look into that. Thank you both!
Sea-Haven
I posted code that does what BeekeeCZ suggests now where is it. Ok found it modified to do only 1 inside *line.
; https://www cadtutor net/forum/topic/54831-trim-extend-to-polyline-boundry/
; simple trim extend of plines or lines inside say a rectang
; by AlanH Nov 2023
(defun c:wow ( / obj1 obj2 intpt oldsnap)
(setq oldsnap (getvar 'osmode))
(setvar 'osmode 0)
(setq obj1 (vlax-ename->vla-object (car (entsel "\nPick object boundary "))))
(setq obj2 (vlax-ename->vla-object (car (entsel "\nPick object to extend "))))
(setq intpt (vlax-invoke obj2 'intersectWith obj1 acExtendThisEntity))
  (if (= (vlax-get obj2 'ObjectName) "AcDbLine")
   (progn
    (vlax-put obj2 'startpoint (list (nth 0 intpt)(nth 1 intpt)(nth 2 intpt)))
    (vlax-put obj2 'endpoint (list (nth 3 intpt)(nth 4 intpt)(nth 5 intpt)))
   (progn
    (vlax-put Obj2 'coordinate 0 (list (nth 3 intpt)(nth 4 intpt)(nth 5 intpt)))
    (vlax-put Obj2 'coordinate 1 (list (nth 0 intpt)(nth 1 intpt)(nth 2 intpt)))
(setvar 'osmode oldsnap)
(princ)
calderg1000
Regards @EnM4st3r
Try this code, extend the inner line with a click on the boundary object
;;;___
(defun c:ext_line (/ snp lp snl x ln lnv lcd ps pe)
  (while
      (princ "\nPick object Boundary ")
    (setq
      snp (cadar (ssnamex (ssget "_+.:E:S" '((0 . "lwpolyline")))))
     (setq
       lp  (mapcar
	     'cdr
	     (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget snp))
       snl (cadar (ssnamex (ssget "wp" lp '((0 . "line")))))
       ln  (list snp snl)
       lnv '()
     (foreach x	ln
       (setq lnv (cons (vlax-ename->vla-object x) lnv))
     (setq lcd (vlax-safearray->list
		 (vlax-variant-value
		   (vla-intersectwith (car lnv) (cadr lnv) acExtendboth)
	   ps  (list (car lcd) (cadr lcd) (caddr lcd))
	   pe  (cdr (member (caddr lcd) lcd))
     (entmod
       (subst (cons 10 ps) (assoc 10 (entget snl)) (entget snl))
     (entmod
       (subst (cons 11 pe) (assoc 11 (entget snl)) (entget snl))
  (princ)
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
EnM4st3r
thanks @Sea-Haven and @calderg1000 for the codes, both work well.
I have sort of a follow-up question but i think i better start a new post for that.
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/split-and-sort-a-pointlist/td-p/1242...
