How to convert 3D point to 2D
luizhcastanho
luizhcastanho
(defun c:test ( / p1 p2 )
    (if (setq p1 (getpoint "\nSpecify Basepoint: "))
        (while (member (car (setq p2 (grread t 15 0))) '(5 2))
            (redraw)
            (if (listp (setq p2 (cadr p2)))
                (grdraw p1 (LM:OrthoPoint p1 p2) -1 1)
                (if (= 15 p2)
                    (setvar 'ORTHOMODE (- 1 (getvar 'ORTHOMODE)))
  ;(set ang (angle (nth 0 (nth 1 p1)) (nth 0 (nth 1 p2)) ))
    (redraw)
 (setq pt1 (list (nth 0 p1) (nth 1 p1)))
 (setq pt2 (list (nth 0 p2) (nth 1 p2)))
 (setq ang (* (angle pt1 pt2) (/ 180 pi)))
pendean
Community Legend
Community Legend
3D Point?
luizhcastanho
The LM:OrthoPoint function returns p1 and p2 in 3d point
Kent1Cooper
Is there a question?
Every "point" [assuming you mean a location, not a Point object] in AutoCAD is 3D.  You may choose to ignore the Z coordinate, and you can remove it from a point coordinate list if you want to, leaving just the X & Y coordinates, in a couple of ways.  If 3DPoint is an XYZ point coordinate list:
(setq 2Dpoint (reverse (cdr (reverse 3DPoint))))
or
(setq 2Dpoint (list (car 3DPoint) (cadr 3DPoint)))
Is this topic about something like that?  If not, explain in more detail.
Kent Cooper, AIA
john.uhden
@Kent1Cooper ,
I think it was you who gets the credit for having pointed out a 3rd method...
(setq 2dpoint (mapcar '* '(1 1) 3dpoint))
or
(setq 2dpoint (mapcar '+ '(0 0) 3dpoint))
Thank you for that.  I like it.
John F. Uhden
