LISP won't take variable value less than 20 unit.
unggansu2
Message 1 of 8
unggansu2
Hello.
I re-created a routine that creates a simple polyline rectangle, based on the distance of two input points, in a set width. The problem is, when the width value is less than 20 unit, it only create a straight polyline.
I'm new to AutoLISP-ing, where did I go wrong?
Here is the file...
Replies (7)
Message 2 of 8
Moshe-A
@unggansu2 ,
Probably the issue is with object snap. you can turn it off before calling (command) like (setvar "osmode" 0)
and reset it back afterword or add "_none" args before any point.
(command "_.PLINE" "_none" pl1 "_none" pl2 "_none" pl3 "_none" pl4 "c")
Moshe
Message 3 of 8
unggansu2
It worked! Thank you!
P.S. : If I set the snap off in the routine, will it come back on after it or do I have to manually activate it again?
Message 4 of 8
Moshe-A
@unggansu2 ,
take a look to this sample 😀
(defun c:test (/ savOSmode)
 ; start program
 (setq savOSmode (getvar "osmode")) ; save osmode value
 (setvar "osmode" 0)  ; turn it off
 ; your program body code here
 (command "._pline" pt1 pt2 pt3 pt4 "_close")
 ; about to exit
 (setvar "osmode" savOSmode); restore osmode value
 (princ)
Message 5 of 8
calderg1000
Regards @unggansu2
Try this code, I made some small changes to it. Enter the reference to point 1 to display the location of point 2 . In some cases it is better to use "Entmake" instead of "Command"
(defun c:wall ()
;searching for input point
  (setq otm (getvar 'orthomode))
  (setvar 'orthomode 1)
  (setq p1 (getpoint "\nFirst point of height : "))
  (setq p2 (getdist p1 "\nSecond Point of height: "))
  (setq tb (getdist "\nWidth : "))
;;;  (setq dis (distance p1 p2))
;start sistem dtr
  (defun dtr (x)
    (* pi (/ x 180.00))
  (princ)
;start looking for polyline point
  (setq pl1 (polar p1 (dtr 180) (/ tb 1)))
  (setq pl2 (polar pl1 (dtr 270) dis))
  (setq pl3 (polar pl2 (dtr 0.0) (/ tb 1)))
  (setq pl4 (polar pl3 (dtr 90) dis))
;start creating polyline
;;;  (command "_.PLINE" pl1 pl2 pl3 pl4 "c")
  (entmake (list '(0 . "LWPOLYLINE")
               (cons 100 "AcDbEntity")
               (cons 410 (getvar 'ctab))
               (cons 100 "AcDbPolyline")
               (cons 90 4)
               (cons 10 pl1)
	       (cons 10 pl2)
               (cons 10 pl3)
               (cons 10 pl4)
               (cons 70 1)
  (setvar 'orthomode otm)
  (princ)
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
Message 6 of 8
Sea-Haven
My $0.05 corrects non ortho Wall.
(defun c:wall ( / p1 p2 tb dis)
(setq oldsnap (getvar 'osmode))
	(setq p1 (getpoint "\nFirst Point : "))
	(setq p2 (getpoint "\nSecond Point : "))
  (setq ang (angle p1 p2))
  (setvar 'osmode 0)
(command "_.PLINE"
p1
p2
(polar p2 (+ ang (/ pi 2.)) tb)
(polar p1 (+ ang (/  pi 2.)) tb)
  "c"
(setvar 'osmode oldsnap)
	(princ)
(c:wall)
Message 7 of 8
unggansu2
Oh God yes!! You finally fixed my angle problem! Thank you!!
Edit: I'm a bit lost when trying to understand the following:
What does the (/ pi 2) means?
Edit 2: Nevermind I got it. Thanks.
Message 8 of 8
Sea-Haven
If we break it down
Using Polar is work out a new point from p2  using angle and distance
We have the angle of the p1 p2 picked points, (angle p1 p2)
As lisp works in radians I have avoided using DTR & RTD funtions, 90 degress is Pi / 2, 180 = pi, 360= 2*pi, 45= pi / 4
The tb is your offset distance.
The points in the pline are done in correct order.
Hope this helps explain
