autolisp code to set "explodable" propery of block "ON"
GeryKnee
GeryKnee
Please inform me wich is the autolisp code to set "explodable" propery of block "ON"
THanks,
Gery
Moshe-A
@GeryKnee ,
Explodable property is part of AcDbBlockTableRecord object which is block definition.
Moshe
(defun c:explchk (/ pick ent elist blocks blkrec)
 (cond
  ((not
     (and
       (setq pick (entsel "\nPick block reference: "))
       (setq elist (entget (setq ent (car pick))))
       (eq (cdr (assoc '0 elist)) "INSERT")
   (prompt "\nObject selected is not block reference.")
  ); case
  ( t
   ; allocating memory
   (setq blocks (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))) 	; AcDbBlockTable
   (setq blkrec (vla-item blocks (cdr (assoc '2 elist))))				; AcDbBlockTableRecord
   (princ (strcat "\nExplodable property is: " (vl-princ-to-string (vla-get-explodable blkrec))))
   ; dispose memory
   (vlax-release-object blkrec)
   (vlax-release-object blocks)
  ); case
 ); cond
 (princ)
paullimapa
Keep in mind you can always use vlax-dump-object function to review object properties that you can get or put
http://docs.autodesk.com/ACD/2011/ENU/filesALR/WS1a9193826455f5ff1a32d8d10ebc6b7ccc-682a.htm
Paul Li
IT Specialist
@The Office
Sea-Haven
;;; DumpIt                                                            ;
;;; Dump all methods and properties for selected objects              ;
(defun C:Dumpit ( / ent)
  (while (setq ent (entsel))
    (vlax-Dump-Object
      (vlax-Ename->Vla-Object (car ent))
  (princ)
;(dumpallproperties (car (entsel)))
Sea-Haven
Hi Gerry please dont take this the wrong way, you have posted tiny requests, mostly about methods, I know your trying to learn, it would be much better if you posted a task. We can provide say a flow chart / steps of how to solve, then you can have a go at coding, we are happy to help. The only way to learn is do real tasks.
So tell us about a new task you want to do.
