Edit LISP to find geometric center and ignore duplicates in a list.
osayed643PD
osayed643PD
Hi, I am still in the process of learning AUTOLISP, and would like to edit some script.  Recently I asked a question and someone gave me this code which I am grateful for. but I have been trying to edit it for the past few days.
basically it selects a polyline, finds intersection points with the polyline and selected objects, then places text at points of intersection
the problem is
1- many times the polyline intersects twice with an object, so it places two text objects
2-  the text should be at the geometric center of the polyline or block if necessary to transform it.
i really have tried and it was too complex for my level .. any help would be truly appreciated.
(vl-load-com)
(defun c:IntersNumbering ( / LM:intersections p s l o z e)
  (or *in-n* (setq *in-n* 0))
  ;; Intersections  -  Lee Mac ;; Returns a list of all points of intersection between two objects ;; for the given intersection mode.
  ;; ob1,ob2 - [vla] VLA-Objects ;;     mod - [int] acextendoption enum of intersectwith method
  (defun LM:intersections ( ob1 ob2 mod / lst rtn )
    (if
      (and
	(vlax-method-applicable-p ob1 'intersectwith)
	(vlax-method-applicable-p ob2 'intersectwith)
	(setq lst (vlax-invoke ob1 'intersectwith ob2 mod)
      (repeat
	(/ (length lst) 3)
	(setq rtn (cons (list (car lst) (cadr lst) (caddr lst)) rtn)
	      lst (cdddr lst))))
    (reverse rtn))
  (if (and (setq p (car (entsel "\nSelect a polyline: ")
			              );car
		        );setq
	   (princ "Select intersecting polylines and blocks, ")
	   (setq s (ssget '((0 . "LWPOLYLINE,LINE,INSERT"))))
	   (or (ssdel p s) t)
	   (setq *in-n* (cond ((setq f (getint (strcat "\nStart with <" (itoa (1+ *in-n*)) ">: ")))
			       (1- f))
			      (*in-n*)))
	   (setq o (vlax-ename->vla-object p))
	   (setq l '()
		 z (getvar 'textsize))
	   );and
    (repeat (setq i (sslength s))
      (setq e (vlax-ename->vla-object (ssname s (setq i (1- i))))
	    l (append (LM:intersections o e acextendnone) l))))
  (and l
       (setq l (vl-sort l '(lambda (p1 p2) (< (vlax-curve-getdistatpoint p p1) (vlax-curve-getdistatpoint p p2)))))
       (foreach p l (entmake (list (cons 0 "TEXT") (cons 10 p) (cons 40 z) (cons 1 (itoa (setq *in-n* (1+ *in-n*))))))))
  (princ)
osayed643PD
here is a sample, the rectangles are the objects that I want to label at the geometric center. the line crossing them is the direction of sorting of the numbering.
ВeekeeCZ
I see that you have probably progressed to the next page in your learning since you were able to figure out that the programmer needs to have a dwg file available. Thumbs up!
So I was able to test the code below on your file and it works fine.
(vl-load-com)
(defun c:IntersNumbering ( / LM:intersections p s l o z e x g)
    (if (and (vlax-method-applicable-p ob1 'intersectwith)
	     (setq lst (vlax-invoke ob1 'intersectwith ob2 mod))
      (repeat (/ (length lst) 3)
	      lst (cdddr lst))))
    (reverse rtn))
  (if (and (setq p (car (entsel "\nSelect a polyline: ")))
	   (or (ssdel p s) t)
			       (1- f))
			      (*in-n*)))
	   (setq z (getvar 'textsize))
      (setq e (vlax-ename->vla-object (ssname s (setq i (1- i)))))
      (if (and (setq x (LM:intersections o e acextendnone))
	       (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-getboundingbox (list e 'll 'ur))))
	       (setq g (mapcar '/ (apply 'mapcar (cons '+ (mapcar 'vlax-safearray->list (list ll ur)))) '(2 2)))
	(setq l (cons (list (car x) g) l)))))
  (and l
       (setq l (vl-sort l '(lambda (p1 p2) (< (vlax-curve-getdistatpoint p (car p1)) (vlax-curve-getdistatpoint p (car p2))))))
       (foreach p l (entmake (list (cons 0 "TEXT") (cons 10 (cadr p)) (cons 40 z) (cons 1 (itoa (setq *in-n* (1+ *in-n*))))))))
  (princ)
osayed643PD
Hi thanks for your encouragement, and I really appreciate your effort.
but the script you just sent doesn't work on my files or the file provided, no output and no errors. The previous one did work though.
osayed643PD
Hi again, I restarted AutoCAD and it works. Thank you kind genius.
