convert "1" to "001"
GeryKnee
GeryKnee
Is there a better syntax to convert "1" to "001" ?
(defun c:xx ( / TempSt)
(setq TempSt(itoa 1))
(while (< (strlen TempSt) 3)
(setq TempSt(Strcat "0" TempSt))
(princ TempSt)
(princ)
Gery
calderg1000
Regards @GeryKnee
Maybe this...
(defun xx (n)
  (setq n (strcat "00" (itoa n)))
(xx 1)
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
CodeDing
I mean, there's only a couple scenarios here, perhaps this
(setq n "1")
(setq sLen (strlen n))
(setq n
  (strcat
    (cond ((= 1 sLen) "00") ((= 2 sLen) "0") (t ""))
    n
  );strcat
);setq
...even better, just remembered this lil gem:
(setq TempSt (itoa 1))
(setq TempSt (strcat (substr "00" (strlen TempSt)) TempSt))
kpblc2000
(_kpblc-string-align 1 3 "0" 3 t)
Link to my functions library is in my sign.
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Алексей Кулик aka kpblc | Aleksei Kulik aka kpblc Facebook | LinkedIn
autolisp.ru
Техническая поддержка программистов Autodesk в СНГ
Библиотека пользовательских lisp-функций | Custom Lisp-function library
ВeekeeCZ
No, there is no built-in function for that.
So since the goal is quite simple I think any algorithm that works and you understand would be good enough.
Kent1Cooper
@GeryKnee wrote:
Is there a better syntax to convert "1" to "001" ? ....
I assume from your posted code that you are not just talking about adding two 0's as at least one reply assumes, but that you will have a target number of characters and want to "pad" a string with leading zeros until it reaches the right length.  This is a topic that has come up numerous times.  Search for things like "leading zeros" or "pad with zeros," and you will find lots of suggestions and approaches.
Kent Cooper, AIA
ronjonp
I'd think you'd want to check your largest number so that the padding can be adjusted for it:
;; Get length of largest integer
(setq p (apply 'max (mapcar 'strlen (setq l '("1" "10" "100" "1000" "10000")))))
;; ("00001" "00010" "00100" "01000" "10000")
(mapcar '(lambda (x) (setq n "") (repeat (- p (strlen x)) (setq n (strcat n "0"))) (strcat n x)) l)
