LISP to Select Dynamic Blocks
3arizona
3arizona
I picked up this lisp on the forum. can this plot lisp be modified to select a dynamic block or both?  I've tried and failed miserably.
(vl-load-com)
(defun c:unitPDF ( / *error* ss ed obj i box ll ur pt1 pt2 pdffile tag val)
  (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break"))
      (princ (strcat "\nError: " errmsg)))
;;;;; Do stuff then error, ESC,
(mapcar 'setvar VarList OldVars)
          (setvar "CMDECHO" 1)
(princ)
  );;;; end *error*
  ;;;;; Main routine
         (setvar "CMDECHO" 0)
     (setq logname (getvar "loginname"))
(command "psetupin" "Details.dwg" "11x17 Landscape" "y")
(command "-PLOT" "n" "model" "11x17 Landscape" "Bluebeam BW.pc3" "N" "Y" "N")
   (setq ss (ssget (list '(0 . "INSERT")'(2 . "UNITS"))))
   (if ss
      (progn
         (setq i 0)
         (while (< i (sslength ss))
            (setq ent (ssname ss i)
                  obj (vlax-ename->vla-object ent)
                  box (vlax-invoke-method obj 'getboundingbox 'pt1 'pt2)
                  ll  (vlax-safearray->list pt1)
                  ur  (vlax-safearray->list pt2)
            (while
               (and
                  (setq ent (entnext ent))
                  (= "ATTRIB" (cdr (assoc 0 (setq edata (entget ent)))))
               (setq tag (cdr (assoc 2 edata)))
               (setq val (cdr (assoc 1 edata)))
               (cond
                  ((= tag "-DO-NOT-EDIT-")   (setq SHEET1 val))
            (setq pdffile
               (strcat
                  "C:/Documents and Settings/" (getvar 'loginname) "/desktop/PDF/"
                  SHEET1 ".pdf"
            (command "-export" "_P" "_W" ll ur "_N" pdffile)
            (setq i (1+ i))
   (princ)
dbhunia
A quick check......change the line.....
To
(setq ss (ssget (list '(0 . "INSERT"))))
I can't check the LISP right now........
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Moshe-A
@3arizona  hi,
Here is my untested correction 😀
Note that in (*error*) function there is this call:
VarList and OldVars are global variables and are not define in this lisp, they maybe exist in your environment but if they don't you will get a bad argument type error if this program is break somehow.
enjoy
Moshe
(vl-load-com)
  (setvar "cmdecho" 1)
  (princ)
 );;;; end *error*
  ;;;;; Main routine
  (setvar "cmdecho" 0)
  (command "._undo" "_begin")
  (if (setq ss (ssget (list '(0 . "INSERT") '(2 . "`*U*"))))
   (progn
    (setq i 0)
    (setq ent (ssname ss i))
    (setq obj (vlax-ename->vla-object ent))
    (if (eq (strcase (vla-get-effectiveName obj)) "UNIT")
     (progn
      (setq box (vlax-invoke-method obj 'getboundingbox 'pt1 'pt2))
      (setq ll  (vlax-safearray->list pt1))
      (setq ur  (vlax-safearray->list pt2))
      (while (and
       (cond
      ); while
      (setq pdffile (strcat "C:/Documents and Settings/" (getvar 'loginname) "/desktop/PDF/" SHEET1 ".pdf"))
     ); progn
    ); if
    (setq i (1+ i))
   ); while
  ); progn
 ); if
 (command "._undo" "_end")
 (princ)
); c:unitPDF
