Lisp to randomly select a set number of instances
jf.bedard22
jf.bedard22
I'm having issues with a lisp.
I'm trying to get a random selection by inputting a quantity rather than a percentage. This lisp is a base that works well for percentages. I am aware this has been already asked.
(defun c:randset (/ ss sl i en el ep pct qty rs)
;; SMadsen Random Number
(defun randnum (/ modulus multiplier increment random)
 (if (not seed)
     (setq seed (getvar "DATE")))
 (setq modulus    65536
    multiplier    25173
     increment    13849
       seed       (rem (+ (* multiplier seed) increment) modulus)
       random     (/ seed modulus)))
 (cond ((or (setq ss (ssget "i")) (setq ss (ssget)))
        (sssetfirst nil ss)
        (setq sl (sslength ss)
               i -1)
        (while (setq en (ssname ss (setq i (1+ i))))
               (setq el (cons en el))))
       (T (alert "\nNo Entities Found")
          (exit)))
 (initget 7)
 (setq pct (getreal "\nPercentage To Randomly Choose:   "))
 (setq qty (fix (* sl pct 0.01)))
 (setq rs (ssadd))
 (while (> qty (sslength rs))
    (setq ep (fix (* sl (randnum)))
          en (nth ep el))
    (if (not (ssmemb en rs))
        (ssadd en rs)))
 (sssetfirst nil rs)
 (princ)
I found another forum where one user suggests to swap a part of the script.
Instead of this:
do this:
(setq qty (geting "\nNumber of items to be selected: "))
I tried the swap but I get an no function definition error. I don't truly understand what I'm doing so if any of you has a solution that would be awesome. Feel free to redirect me if there is a more appropriate place to ask such questions.
As a sidenote I posted this on reddit but I'm thinking this here may be more appropriate.
ВeekeeCZ
Rewritten to be more efficient.
(defun c:randset ( / randnum ss sn n e)
    (if (not seed)
    (setq modulus    65536
	  multiplier    25173
	  increment    13849
  (if (and (or (and (ssget "_I")
		    (sssetfirst nil)
		    (setq ss (ssget "_P")))
	       (setq ss (ssget)))
	   (not (initget 0))
	   (setq n (getint (strcat "\nNumber of items of " (itoa (sslength ss)) ": ")))
	   (or (<= n (sslength ss))
	       (prompt "\nError: The selected number has exceeded the possible maximum."))
	   (setq sn (ssadd)))
    (repeat n
      (setq e (ssname ss (fix (* (sslength ss) (randnum)))))
      (ssadd e sn)
      (ssdel e ss)))
  (if sn (sssetfirst nil sn))
  (princ)
jf.bedard22
Thanks! That's a nice little touch to have added a count of the selected items!
