SET POLYLINE TO ELEVATION OF ZERO
Message 1 of 8
Hi I was trying to make a lisp that lets you select or window polylines and set them all to a elevation of zero
can someone help me out. thanks
Accepted solutions (4)
Replies (7)
Message 2 of 8
pbejse
(defun c:PZero ( / 3p plines i ev coord)
(defun _3p (l)
  (if l
    (cons (list (Car l) (cadr l) 0.0) (_3p (cdddr l)))
  (if (setq plines (ssget '((0 . "*Polyline"))))
    (repeat (setq i (sslength plines))
      (setq ev (vlax-ename->vla-object (ssname plines  (setq i (1- i)))))
  	(if (eq "AcDb3dPolyline" (vla-get-ObjectName ev))
	  (vlax-put ev 'Coordinates (apply 'append (_3p (vlax-get ev 'Coordinates))))
		(vlax-put ev 'Elevation 0.0)
  (princ)
HTH
Message 3 of 8
Kent1Cooper
You can do this with no command or routine, almost as easily as with one.  Just grab everything in the area that includes the desired Polylines, and in Properties, pull down the slot that says "All" [= all objects in the selection, by type] and pick Polyline to limit the selection to just those:
then pick in the Elevation slot under Geometry, and give it 0:
and they'll all change together.
Kent Cooper, AIA
Message 4 of 8
calderg1000
Saludos  @Anonymous
De otra forma, mover los objetos a un lugar muy lejano y luego devolverlos
(defun c: ch0 (/ s p1 p2 p2 i)
  (setq s (ssget))
  (setq p1 '(0 0 0)
        p2 '(0 0 10e50)
        p3 '(0 0 -10e50)
  (repetir (setq i (sslength s))
    (vla-move (vlax-ename-> vla-object (ssname s (setq i (1- i))))
              (vlax-3d-point p1)
              (vlax-3d-point p2)
              (vlax-3d-point p1)
              (vlax-3d-point p3)
(princ)
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
Message 5 of 8
ВeekeeCZ
@calderg1000 wrote:
Saludos  @Anonymous
  (setq s (ssget))
  (setq p1 '(0 0 0)
        p2 '(0 0 10e50)
        p3 '(0 0 -10e50)
  (repeat (setq i (sslength s))
              (vlax-3d-point p1)
              (vlax-3d-point p2)
              (vlax-3d-point p1)
              (vlax-3d-point p3)
(princ)
Spanish autocorrection?
Message 6 of 8
@pbejse thank you for you help this is perfect
Message 7 of 8
@Kent1Cooper
thanks you. this is how I moved everything previously to elevation 0 as well, but was curious on how to do so in a lisp. I am in the process of learning how to write them myself. thanks
Message 8 of 8
@calderg1000
gracias por tu ayuda. estoy muy agradecido.
