print textscr
print textscr
avinash00002002
print textscr
avinash00002002
Hi!
I have a lists that want to print in screen but it will not aligned.
please find attached image.
Avinash
Sea-Haven
You may need to look at your strings maybe add tabs seperating the values.
(setq str "a b c d eee hhh")
(setq str2 (strcat "a\tb\tc\td\teee\thhh"))
(alert (strcat str "\n" str2))
avinash00002002
I tried but not printed in one line (aligned).
Sea-Haven
Understand did not work, the issue is with the text font used to display the output, if in say mtext would use monotxt then it would work. The only way I got it to work was to write to a file with tabs and open with notepad, you can open notepad from Autocad using SHELL. (command "shell" "notepad d:\\acadtemp\\tabtest.txt")
diagodose2009
You can replace TextScreen with Notepad.
Do you wish replace TextScreen with Wordpad.exe?
Command:Q2
First corner:
Dati coltul opus:
Get BlockName (Name/Entsel/About)=E
Selectati un blockmodel:_.ZOOM
Specify corner of window, enter a scale factor (nX or nXP), or
[All/Center/Dynamic/Extents/Previous/Scale/Window/Object] <real time>: _w
Specify first corner: Specify opposite corner:
Command:
Type ExportedFile(3d/2d)=3
