Lisp to Pull Attribute Text From a Block and Assign to Variable
SYPine
SYPine
Below is a code that I have been working on to pull values from the "Title Block" and sets those values to variables so I can export them to an Excel file later on. I can use the below code to edit the values (vla-put-textstring att), but I can't pull them into a variable for some reason. The line that is giving me trouble is "(setq customer (vla-get-textstring att))". (Its not just the customer though, its all of the lines that are trying to assign the value to a variable) I receive the error "bad argument type: FILE "XXXXXXX" (With "XXXXXXX" being the value that is currently in the block attribute). I'm sure its something small that I am overlooking as I am quite the novice, but thank you for your time and input.
(setq ss1 (ssget "X" (list '(0 . "INSERT") (cons 2 "TITLEBLOCKTA"))))
(repeat (setq i (sslength ss1))
 (princ "\nGrabbing From BOM")
 (foreach att (vlax-invoke (vlax-ename->vla-object (ssname ss1 (setq i (1- i)))) 'getattributes)
  ;Get Job Number
  (if (= "TB-JOB" (strcase (vla-get-tagstring att)))
   (progn
    (princ "\nGrabbing Job Number")
    (setq jobnum (strcase (vla-get-textstring att)))
    (princ "\n" jobnum)
  ;Get Descritpion
  (if (= "TB-TITLE1" (strcase (vla-get-tagstring att)))
   (progn
    (princ "\nGrabbing Description")
    (setq description (strcase (vla-get-textstring att)))
    (princ "\n" description)
  ;Get Customer
  (if (= "TB-CLIENT" (strcase (vla-get-tagstring att)))
   (progn
    (princ "\nGrabbing Customer")
    (princ "\n" customer)
  ;Get City and State
  (if (= "TB-LOCATION" (strcase (vla-get-tagstring att)))
   (progn
    (princ "\nGrabbing Location")
    (setq citystate (strcase (vla-get-textstring att)))
    (princ "\n" citystate)
	;Variables Recieved----------
	;Job Number - jobnum
	;Description - description
	;Customer - customer
	;City and State - citystate (TOWN, STATE ABBR.)
 );foreach
);repeat
dlanorh
  ;Get Job Number
   (progn
    (princ "\n" jobnum)
  ;Get Descritpion
   (progn
  ;Get Customer
   (progn
  ;Get City and State
   (progn
 );foreach
);repeat
After you assign each Attribute text string to a variable you are trying to (princ) the value. However the lines are constructed incorrectly and autolisp thinks your are writing to a file
(princ "\n" variable_name)
where variable_name is the pointer to a file. Thus the error you are seeing.
The correct format is
(princ (strcat "\n" variable_name))
I am not one of the robots you're looking for
ronjonp
Maybe something like this?
;; Is there more than one titleblock?
(if (setq ss1 (ssget "_X" '((0 . "INSERT") (2 . "TITLEBLOCKTA"))))
    (setq o (vlax-ename->vla-object (ssname ss1 (setq i (1- i)))))
    (setq a (mapcar '(lambda (x) (list (vla-get-tagstring att) (vla-get-textstring att)))
		    (vlax-invoke o 'getattributes)
    ;; this will store the variables in a list 'r'
    (setq r (cons a r))
    (mapcar 'print (car r))
SYPine
I can't believe I overlooked that 🙃. Worked great and thanks for your help.
dlanorh
The error message was a dead givaway. Sometimes you're so involved you can't see the wood for the trees. You might find this page useful in hunting down the cause of errors
SYPine
This will be really helpful! I appreciate it
