profile view invert
profile view invert
AR.SION
profile view invert
AR.SION
Hi I need help to make this work. I am trying to make a lisp that will insert a block to profile view but I need to add this transparent command 'pse as my insertion point. thanks
AR.SION
sorry here is the lisp.
ВeekeeCZ
Try this?
(command "_.-INSERT" "INVERT" "_S" 1 "_R" 90 (c:PSE))
Kent1Cooper
May we see the code for the PSE command?
If usage as a transparent command 'PSE is the need, don't think (C:PSE) will work, because I don't think a defined custom command can be called that way except at the Command: prompt, but in the suggested code it's at the insertion-point prompt inside an Insert command.  I believe you can use transparent commands like that in command macros, but I don't think you can in AutoLisp routines.
But if you show us what PSE does, very likely the same functionality can be built into the routine in another way.
Kent Cooper, AIA
john.uhden
OR, if c:PSE is supposed to return an insertion point, then he can call C:PSE before the command to save the result and put it at the end of (command ...)
John F. Uhden
ВeekeeCZ
This one works.
(vl-load-com)
(defun c:INV nil
  (vla-sendcommand
    (vla-get-activedocument (vlax-get-acad-object))
    "_.-INSERT\rINVERT\r_S\r1\r_R\r90\r'PSE\r")
  (princ)
AR.SION
Amazing!!! thank you so much  Sir BeekeCZ  and to all who replied you guys are so helpful. thanks again.
