- Mute
- Permalink
- Report
Hi all,
First of all, Thanks for the effort and time you spend for this AutoCAD community.
Can some body let me know if there is a lisp program to draw lines, exactly dividing ( the user should be able to input the number of spaces he/she wants between the lines) the space between 2 polylines /lines ( Parallel or on parallel). I am using the lisp LineBetween currently, but it has its own limitations, like it will not work when the UCS is rotated, the midway line created is a LINE rather than a polyline even if the original lines selected are polylines, etc.
Purpose:
I basically use this to make concrete scoring while doing storefront concrete, where I have to tell the general contractor where to give construction joints/ control joints. Depending upon the structural stoop and building wall projections, I have to decide whether I have to divide the space equally in 2, 3, 4 parts, etc.
Any help in this regard is highly appreciated.
VM
