Lisp to draw a 3 point rectangle and hatch with the given angle
francine.zimmermannSRSWJ
Message 1 of 13
I found a Lisp on Internet to draw a rectangle by given 2 point and a thickness dimension.
On that Lisp I add a command line to make a Hatch. It works, apart from the angle which is not taken into account.
Can anyone help me please?
Replies (12)
Message 2 of 13
Kent1Cooper
The command-line usage of the Hatch command wants input for the rotation in degrees, but the 'ang' variable is in radians.  So:
(command "-hatch" "S" "L" "" "P" "Brick" RW* (cvunit ang "radian" "degree") "" "")
Kent Cooper, AIA
Message 3 of 13
The angle is now working but the hatch is not oriented along the line but is rotated by 90°.
How can I adjust that?
Message 4 of 13
ВeekeeCZ
Add it?
(cvunit (+ ang (/ pi 2)) "radian" "degree")
Message 5 of 13
I tested it, now it is working.
I have an other request, is it possible to set the hatch origin on the line P1 P2?
Message 6 of 13
ВeekeeCZ
Just run the -hatch command and follow the prompts. There is the "Origin" option, so to answer your question, yes, it is.
Message 7 of 13
Yes I know that I can redefine the origin but is it not possible to do it directly in the lisp.
It's restrictive if each time I hatch I have to redefine the origin, knowing that line P1 P2 is given
Message 8 of 13
ВeekeeCZ
@francine.zimmermannSRSWJ
what I meant was to run (type) the command, see what options or key letters need to be typed, and then fill them into your script line...
(command "-hatch" "S" "L" "" "P" "Brick" RW* (cvunit ang "radian" "degree") "_O" "_S" ... "" "")
It's not a rocket science.
Message 9 of 13
ok I understand
(command "-hatch" "S" "L" "" "P" "INSULATION_" RW* (cvunit (+ ang (/ pi 2)) "radian" "degree") "O" "S" P1 "" "")
Message 10 of 13
I have a last question : is it possible by stretching the thickness of the rectangle the hatch will be adjust automatically? Like with a dynamic block?
Message 11 of 13
ВeekeeCZ
If you have HPASSOC 1 and HPDRAWORDER 3 or 1 it should work that way.
Message 12 of 13
I have those variable like what you have written. It change the hatch contour but I was meaning the hatch scale
Message 13 of 13
Sea-Haven
Because a hatch is a repeating pattern you have say the height fixed then it will repeat the pattern, yes you are correct you could change the height via new scale. But it will increase the X spacing.  I have a different way to do this using a pline and the code asks for height so in this case I would erase and create again. Sorry copyrighted no code, but happy to help if you want to have a go, otherwise google "Insulation Autocad lisp"
