Command Description displaying when typing in command shortcut
traci_haberghamJQEJT
Morning all,
I'm hoping this is an easy one but I can't find the answer anywhere.
How do you display a description of what the command is when Autocad lists them when you start to type it in (see image).
Thank you
T
Moshe-A
@traci_haberghamJQEJT  hi,
This is not the place to ask for more help. hover the commnad from a  tool or go to system help
ВeekeeCZ
That's related to the ALIASes defined in the PGP file. It's automatic and can't control whether you want to show or hide them.
PL is an alias, and PLINE is the command's full name.
If you want something similar for your custom routines, name them with the full name and then create a short alias.
You can edit the PGP file directly or use the built-in editor:
eh?
This is great, didn't know this existed.  Thank you 🙂
