Lisp to Create viewport from selected rectangles from model-space
i found this lisp, but i dont want to make that rectangle and just click on a reclangle already made (and of course,make a multiple selection of reclangle from model-space).I dont mind if the lisp will generate the "n" numbers of viewport all told
;|------------ Viewport Creator ----------------
	    q_|_|| _\|| q_|| _\|
  - Select area
  - ask for viewport scale
  - Go to last layout (first at right)
  - Ask for center point of viewport
  - Create a viewport
  - view the selected area with the viewport
  Create stations for Prestresed tendon
  Author: Hasan M. Asous, 2010
	ALL RIGHT RESERVED TO ALL
  Contact: HasanCAD @ TheSwamp.org,
           asos2000 @ CADTutor.net
           HasanCAD@gmail.com
  Version: 1      2012 07 01
________________________________________________
	;     q_|_|| _\|| q_|| _\|     ;
	;       Mainroutine Start      ;
(defun c:NV (/	      doc      p1	p2	 temp	  mp
	     scl      SC       cd:DWG_LayoutsList	  res
	     a	      b	       vpp	vpdoc	 vp
  (vl-load-com)
  (setq Doc (vla-get-ActiveDocument (vlax-get-Acad-Object)))
  (setq p1 (getpoint "\Select objects to view:"))
  (setq p2 (getcorner p1))
  (if
    (< (car (trans p2 1 0)) (car (trans p1 1 0)))
     (setq tmp p1
	   p1  p2
	   p2  tmp
     T
  (setq	mp (list (/ (+ (car p1) (car p2)) 2)
		 (/ (+ (cadr p1) (cadr p2)) 2)
		 0.0
  (setq	sc (cond ((getint (strcat "\nWhat is Viewport Scale 1: <"
				  (itoa	(setq sc (cond (sc)
						       (50)
		 (sc)
  (setq	cd:DWG_LayoutsList
	 (vlax-for % (vla-get-layouts Doc)
	   (setq res (cons (list (vla-get-name %)
				 (vla-get-TabOrder %)
			   res
  (setvar "CTab"
	  (caar	(vl-sort cd:DWG_LayoutsList
			 '(lambda (a b) (> (cadr a) (cadr b)))
  (setq VPDoc (vla-get-PaperSpace doc))
  (setq VPp (vlax-3D-point (getpoint "\nSelect Point for Viewport")))
  (setq	VP (vla-AddPViewport
	     VPDoc
	     VPp
	     (/ (- (car p2) (car p1)) sc)
	     (/ (- (cadr p2) (cadr p1)) sc)
  (vla-display VP :vlax-true)
  (vla-put-mspace doc :vlax-true)
  (vla-put-activepviewport Doc VP)
  (vla-zoomcenter
    (vlax-get-acad-object)
    (vlax-3d-point mp)
    1.0
  (vl-cmdf "_.zoom" (strcat (RTOS (/ 1.0 SC)) "xp"))
  (vla-regen (vla-get-activedocument (vlax-get-acad-object))
	     acActiveViewport
  (vla-put-mspace doc :vlax-FALSE)
  (VLA-PUT-DisplayLocked VP :vlax-true)
	;       Mainroutine End        ;
(princ "\n Type  NV  to Invoke")
(princ)
Dear Sir,
I have work on this lisp, but not success.
Can you please help, how to operate this lisp with video.
Thanks.
I know this is an old thread, so I might not reach anyone, but I tried this LISP and it worked a couple times(although a little differently than I thought, with the scaling), but I would love to locate a LISP that works as intended. It seems to "nearly work"!
Michael
dlanorh
Origin of lisp is HERE
Various partial code updates and variations
I am not one of the robots you're looking for
