Auto dimension intersecting lines
dani-perez
dani-perez
Hello all,
I would like to be able to auto dimension all intersecting points of a grid in a specifyc layer (selecting all these grid-lines, plines or xlines) with all intersecting line or pline points in other specifyc layer (Muros).
Dimensions shouldn't work with the grid.
I am attaching a drawing as a sample.
P.D: I have been looking for a Lisp in the fórum but I couldnt find it for my specifyc task.
Thanks all.
Sea-Haven
Pretty sure there was a qdim way of doing it, will try to find.
Yep Qdim select the green boxes then the point for the dim lines, all done.
If want midpoint dont need red lines just use mid for pick point.
need a bit more research its doing horizontal not ver probably a variable needs to be set.
Have a look at this https://www.youtube.com/watch?v=bQcaSHYCM9A
