Lisp to Create multiple viewport
francine.zimmermannSRSWJ
Message 1 of 45
I'm looking for a lisp to create multiple viewport.
I've found a lisp on the internet that almost meets my expectations, its name is NV.lsp. (see attached file)
I need 2 things, redo the same operation several times and insert the window not in the centre but in relation to a corner (for example the bottom left corner).
Does anyone know how to integrate this into this lisp?
Thank you very much in advance for the help
Replies (44)
Message 41 of 45
paullimapa
In the other thread others have already provided responses including looking at an already existing app that handles rotated vports:
Re: i am using AI to write a script for setting viewports and it is telling me that It cant find my ...
Paul Li
IT Specialist
@The Office
Message 42 of 45
Sea-Haven
Look at my prior posts I use the method of walking down a line/pline so rectangs are auto rotated. Then just make layouts that match with mviews rotated to suit.
Message 43 of 45
saqib_tipa
@Sea-Haven .
Hi, could you share this Lisp.?
Thanks.
Message 44 of 45
Sea-Haven
It has a front end for setting up correct title block/sheet size  and scale, its not free but real cheap like a cup of coffee as I normally edit it to suit an end user requirements, saves the back and forth getting it right.
Message 45 of 45
dipesh_air
hi, it works as expected would it possible to undo viewport when I mistakenly draw unintended viewport? and for me viewport scale is not being set as per selection from list.
