Lisp to Create multiple viewport
francine.zimmermannSRSWJ
Message 1 of 48
I'm looking for a lisp to create multiple viewport.
I've found a lisp on the internet that almost meets my expectations, its name is NV.lsp. (see attached file)
I need 2 things, redo the same operation several times and insert the window not in the centre but in relation to a corner (for example the bottom left corner).
Does anyone know how to integrate this into this lisp?
Thank you very much in advance for the help
Replies (47)
Message 2 of 48
pendean
Community Legend
Community Legend
May I ask, why not just create a redefined layout(s) with those viewports locations and scales in a template file(s) then just import them when needed?
Message 3 of 48
In the model space I have a section over 10m long with lots of details.
When I prepare the multiple viewports it's more visible in the model space.
Message 4 of 48
paullimapa
Attached is updated code with the following modifications:
1. Vport layout placement is at lower left corner
2. Default setting to switch back to Model vs staying in Layout
3. NV loops until Esc or Enter during first point of view selection
Give this a try and let me know if that works for you.
Paul Li
IT Specialist
@The Office
Message 5 of 48
Thank you very much, I'm going to show it to my colleagues to see if it's what they'd like.
Maybe I'll come back with a small request, but for me it's what I was looking for.
Message 6 of 48
paullimapa
Glad this worked for you…cheers!!!
Paul Li
IT Specialist
@The Office
Message 7 of 48
Sea-Haven
This walks along a P/Line following it and making rectangs that match your title block at scale. Second step is make layouts. 2nd version is just copy rectangs, you can rotate and move before making layouts.
Happy to discuss.
Message 8 of 48
Hi Paul,
I showed it to my colleagues and they asked me if it was possible to choose several windows view before inserting into the layout, (all choose window will have the same scale)
Is that possible?
Message 9 of 48
Is this also based on Lisp?
Message 10 of 48
paullimapa
I've renamed & created a new function called NVM.lsp that allows for multiple view selections.
Let me know if this works out for you.
Paul Li
IT Specialist
@The Office
Message 11 of 48
Sea-Haven
Yes my code is lisp, you want something like this when making say the 1st rectang. Then just copy and rotate to suit.
Message 12 of 48
Hello Paul,
Thank a lot for your help, my colleagues asked me one last thing:
Is it possible, once I've chosen a set of views, to insert them in the same chosen layout ?
For exemple rectangle 1, 2 and 3, insert in Layout 1.
If I want to change layout I have to redo the command
Message 13 of 48
paullimapa
Sure, I've modified the NVM.lsp code to do just that.
I also added an option to bring up a VPort Scale list in a dialog box to select from.
Let me know how that works out for you!!!
Paul Li
IT Specialist
@The Office
Message 14 of 48
Hello Paul,
This is exactly what we were looking for, thank you very much for your help, have a good weekend!
Message 15 of 48
paullimapa
glad to have helped & you have a great weekend too...cheers!!!
Paul Li
IT Specialist
@The Office
Message 16 of 48
allanthebruce
Hi There,
Hope you can help, Im getting this error??
Select first point of view or Enter to Exit:
Select second point of view:
1 View Selected...
1 Views Selected...Regenerating layout.
Command:
Select Point for 1 of 1 Viewports: Error: divide by zeroRegenerating model.
Command:
Hope you can help and appreciate it.
Allan
Message 17 of 48
allanthebruce
Hope you can help,
Could this be modified to select a block with attribute number (rectangle of viewport size-and attribute sheet number) , then with a xy insertionfor viewpost size bottom left 0,0 user can modify, then it creates viewport,  names it the attribute sheet number? Just 1 attribute viewport per sheet.
I Can send a sample out of outcome?
Allan
Message 18 of 48
paullimapa
So the attribute contains the name of the layout the vport should go onto?  What happens when such a layout does not exists?
Attach a dwg with the Block and attribute so I can take a look.
Paul Li
IT Specialist
@The Office
Message 19 of 48
allanthebruce
Thanks for getting back to me.
This attached is the viewport with the attribute name, note its insertion point also. If I had multiple say 5 it could either add or create and name the viewport. I do have a titleblock also so maybe it just adds the viewport.
Hope that makes sense.
Thankyou kindly
Allan
Message 20 of 48
paullimapa
I see that this is the name of the block and there's only one attribute:
More questions:
1. Will the block being selected always be named as A1_horizontal and the Attribute Tag name is MAPSHTNUM
2. In this case the Attribute value is "01" and that means it'll go onto layout named "1"?
3. As I asked earlier, let's say the Attribute value is "02" but there's no layout named "2", should a new empty layout be created and be given name of "2"?
4. Like with previous NVM.lsp should a request be made for the user to select location on the matching layout to place the Vport?
5. Like with previous NVM.lsp should a request for the Vport scale be only prompted for once to apply to all Blocks selected or have the Vport scale prompt window appear before adding each Vport onto the corresponding layout?
Paul Li
IT Specialist
@The Office
