Macro for changing dimstyle after DIMANGULAR
kubaszymanski
kubaszymanski
I have a problem with writing a macro to set another dimstyle after using DIMANGULAR.
I did it for DIMRADIUS and it works well.
I think the problem is that user have to select two lines to determine the angle
For the Radius
^C^C-layer;set;FULL;;_Dimstyle;R;"RADIUS1";DIMRADIUS \;_Dimstyle;R;"DIM1";
For the Angle
^C^C-layer;set;FULL;;_Dimstyle;R;"ANGLE1";DIMANGULAR \\;_Dimstyle;R;"DIM1";
Kent1Cooper
Do they not both need an additional \ for the positioning of the dimension line?
But in addition, do you need separate Dimension Styles for radial vs. angular measurements?  Every Style has settings for both linear [which radial Dimensions are] and angular varieties, so you should be able to handle both in one Style.
Kent Cooper, AIA
Moshe-A
@kubaszymanski  hi,
DIMANGULAR need extra pause '\' and does not need the following enter ';'
Moshe
kubaszymanski
1. It depends on your need. Radius work well like that
2. Yeah.. I know, but I need to stick with the client standards so I'm looking for some time savers..
kubaszymanski
Hi Moshe,
thanks... so simple 🙂
