Below are the changes I made:
I'm not sure if you only want to select 1 Block at a time but if you do then change the following:
(setq ss (ssget '((0 . "INSERT") (2 . "POINTBORNE"))))
To this:
; filter selection to only 1 block
(setq ss (ssget "_+.:E:S" '((0 . "INSERT") (2 . "POINTBORNE"))))
If selected item then first things to do are the following:
(setq ss (ssname ss 0)) ; get entity of first/only item in selection set
(setq attreq (getvar"attreq")) ; save current setting
(setvar "attreq" 0) ; set attribute value prompt off
Then instead of these lines of code that doesn't work:
; (setq nbornier (entget (car ss) '("NBORNIER")))
; (setq nbornier (cdr (assoc 1 nbornier)))
; (setq pborne (entget (car ss) '("PBORNE")))
; (setq pborne (cdr (assoc 1 pborne)))
; (setq nfils (entget (car ss) '("NFILS")))
; (setq nfils (cdr (assoc 1 nfils)))
; (setq ptborne (entget (car ss) '("POINTBORNE")))
; (setq ptborne (cdr (assoc 10 ptborne)))
Use the following:
(setq nbornier (getpropertyvalue ss "NBORNIER")) ; get block attribute values
(setq pborne (getpropertyvalue ss "PBORNE"))
(setq nfils (getpropertyvalue ss "NFILS"))
(setq ptborne (cdr (assoc 10 (entget ss)))) ; get block's insertion point
Instead of the following to insert new block & fill out attributes:
;; Insertion du bloc "BORNIER"
; (command "INSERT" "BORNIER" ptborne "1" "1" "0" "")
; (setq bornier (entlast))
; (command "-ATTEDIT" "1" bornier "" "ALL" nbornier "")
Use the following:
(command "_.INSERT" "BORNIER" ptborne "1" "1" "0") ; insert block using selected block's insertion point
(setpropertyvalue (entlast) "NBORNIER" nbornier) ; place value into inserted block's attribute
Then for inserting the next block instead of these lines of code:
;; Insertion des blocs "BORNE"
; (setq borne_pt ptborne)
; (repeat (length ss)
; (command "INSERT" "BORNE" borne_pt "1" "1" "0" "")
; (setq borne (entlast))
; (command "-ATTEDIT" "1" borne "" "NFILS" nfils "")
; (command "-ATTEDIT" "1" borne "" "PBORNE" pborne "")
; (setq borne_pt (mapcar '+ borne_pt '(10 0))) ;; Décalage horizontal de 10 unités
Use the following:
(command "_.INSERT" "BORNE" ptborne "1" "1" "0") ; insert block using selected block's insertion point
(setpropertyvalue (entlast) "PBORNE" pborne) ; place value into inserted block's attribute
(setpropertyvalue (entlast) "NFILS" nfils) ; place value into inserted block's attribute
Now I'm not sure what you want to do with this...do you want to move this newly inserted block 10 units to the right?
After all done then restore original setting:
(setvar "attreq" attreq) ; restore original setting
