Add value if item in text is number
neam
Message 1 of 15
neam
Hi everyone
How to add a value to all number item in text string like this:
Old Text=Station: 10 No.=1
Value=1.5
New Text=Station: 11.5 No.=2.5
Replies (14)
Message 2 of 15
komondormrex
@neam
hi there,
are there other strings with more than 2 numbers in a string, but to change only two?
Message 3 of 15
neam
Hi komondormrex
thank you for attention
Yes, there may be more than two numbers in the text.
Add a constant value to all numbers in the text.
Message 4 of 15
komondormrex
like what, i mean what chars are before/after the numbers?
Message 5 of 15
neam
I apologize if I didn't express my meaning correctly.
It may be after or before the number of any character.
Is it possible to identify numbers within a text?
For example:
Station:10  No.=1  Page 2
Message 6 of 15
neam
If it gets a little difficult, I can change the characters before and after the numbers to spaces.
Station 10 No. 1 Page 2
Message 7 of 15
ВeekeeCZ
FYI
Lees parse func can identify them correctly
https://www.lee-mac.com/parsenumbers.html
Message 8 of 15
komondormrex
so the page number stays 2 while station and no get added?
Message 9 of 15
neam
Hi beekeeCZ
Thank you for attention
I use this function in lisp, but i cannot replace new value to text string.
;; Author: Lee Mac, Copyright © 2011 - www.lee-mac.com ;;
(defun incarray:splitstring ( str / lst )
(setq lst (vl-string->list str))
(read (vl-list->string (vl-list* 40 34 (incarray:split lst (< 47 (car lst) 58)))))
(defun incarray:split ( lst flg )
(cond
( (null lst) '(34 41))
( (member (car lst) '(34 92))
(if flg
(vl-list* 34 32 34 92 (car lst) (incarray:split (cdr lst) nil))
(vl-list* 92 (car lst) (incarray:split (cdr lst) flg))
( (or (< 47 (car lst) 58) (and (= 46 (car lst)) flg (< 47 (cadr lst) 58)))
(if flg
(vl-list* (car lst) (incarray:split (cdr lst) flg))
(vl-list* 34 32 34 (car lst) (incarray:split (cdr lst) t))
( flg (vl-list* 34 32 34 (car lst) (incarray:split (cdr lst) nil)))
( (vl-list* (car lst) (incarray:split (cdr lst) nil)))
;; Parse Numbers - Lee Mac
;; Parses a list of numerical values from a supplied string.
(defun LM:parsenumbers ( str )
( (lambda ( l )
(read
(strcat "("
(vl-list->string
(mapcar
'(lambda ( a b c )
(if (or (< 47 b 58)
(and (= 45 b) (< 47 c 58) (not (< 47 a 58)))
(and (= 46 b) (< 47 a 58) (< 47 c 58))
b 32
(cons nil l) l (append (cdr l) '(()))
(setq num (getreal "Add Value: "))
(setq SS (ssget (list (cons 0 "TEXT,MTEXT"))))
(repeat (setq CNT (sslength SS))
(setq ENTITY (entget (ssname SS (setq CNT (1- CNT)))))
(setq TXTSTRING (strcase (cdr (assoc 1 ENTITY)) NIL))
(setq par (LM:parsenumbers TXTSTRING))
(setq x1 ())
(while (/= (car par) nil)
(setq x1 (reverse (append (list (rtos (+ num (car par)) 2 2)) x1)))
(setq par (cdr par))
(setq x2 (incarray:splitstring TXTSTRING))
Message 10 of 15
ВeekeeCZ
That's just a starting point, it needs to be adjusted. Specifically to replace READ with something which keeps it as strings..
Anyhow, where is his incarray:splitstring coming from?
Message 11 of 15
neam
That's absolutely correct.
I don't know exactly which forum I found it on.
I think it was from the Lee Mac.
Message 12 of 15
neam
I apologize for the late reply.
Due to my poor English, I have to use a translator, which slows down the work.
no: all number included Station and No. and Page are change.
I understand that the page cannot be decimal.
it is only an example:
Old= Station 10 No. 1 Page 2
New= Station 11.5 No. 2.5 Page 3.5
Message 13 of 15
komondormrex
so confirm if i am right.
you want every number that is in the textstring of all selected *texts to be changed by adding some number, and there will be no other number in the string to stay intact, correct?
Message 14 of 15
neam
Absolutely Yessssssssssssssssssssssssssssssss
Message 15 of 15
komondormrex
well, check the following. i did thou sort of filtering for words preceding numbers to be added, just in case)
;	'add_value_texts' custom command adds value to certain numbers within text strings
;	komondormrex, feb, 2025
;	totally lm free
(defun string_to_list (string delimiter_string / out_list)
    (setq char_list (vl-string->list string))
  (defun parse_string (char_list delimiter_string / substring)
    (setq char_list_remainder char_list)
    (if (vl-some '(lambda (ascii_code)
              (setq substring (cons ascii_code substring)
                  char_list_remainder (cdr char_list_remainder)
              (member ascii_code (vl-string->list delimiter_string))
              char_list
      (progn
        (setq delimiter_char (chr (car substring)))
          (if (/= "" (setq substring (vl-list->string (reverse (cdr substring)))))
          (setq out_list (append out_list (list substring delimiter_char)))
          (setq out_list (append out_list (list delimiter_char)))
        (parse_string (setq char_list char_list_remainder) delimiter_string)
      (if (/= "" (setq substring (vl-list->string (reverse substring))))
        (setq out_list (append out_list (list substring)))
     out_list
  (parse_string char_list delimiter_string)
(defun check_int (number)
  (if (zerop (abs (rem number 1))) (itoa (fix number)) (rtos number))
(defun c:add_value_texts (/ addition text_sset new_text_list do_add old_text_group)
  (if (null addition_saved) (setq addition_saved 1.5))
  (if (null (setq addition (getreal (strcat "\nEnter addition number <" (rtos addition_saved) ">: "))))
	(setq addition addition_saved)
	(setq addition_saved addition)
  (if (setq text_sset (ssget '((0 . "*text") (1 . "*#*"))))
    (foreach text (vl-remove-if 'listp (mapcar 'cadr (ssnamex text_sset)))
      (setq new_text_list nil do_add nil)
      (foreach sub_string (string_to_list (cdr (setq old_text_group (assoc 1 (entget text)))) " :=")
        (if (and (wcmatch (strcase sub_string) (strcase "Station*,No.*,Page*"))
                 (null do_add)
            (setq do_add t)
        (if (and (vl-every '(lambda (asc) (member asc (vl-string->list "0123456789.")))
                   	    (vl-string->list sub_string)
                 do_add
            (setq new_text_list (append new_text_list (list (check_int (+ (atof sub_string) addition))))
            	  do_add nil
            (setq new_text_list (append new_text_list (list sub_string)))
      (entmod (subst (cons 1 (apply 'strcat new_text_list)) old_text_group (entget text)))
  (princ)
