how can quick mirror for a batch of multileader by their vertex (pos x)
skchui6159
Message 1 of 10
skchui6159
As topic, anyone know how can quick mirror that (with only select Multileader) (with erase) with a lisp?
The Circle is not need(for indicate the location only).
Accepted solutions (3)
Replies (9)
Message 2 of 10
skchui6159
Message 3 of 10
ВeekeeCZ
Possibly like this.
(vl-load-com)
(defun c:MirHorMleader ( / s i c e h v)
  (if (setq s (ssget "_:L" '((0 . "MULTILEADER"))))
    (repeat (setq i (sslength s))
      (if (and (setq e (ssname s (setq i (1- i))))
	       (setq c (vlax-safearray->list (vlax-variant-value (vla-getleaderlinevertices (vlax-ename->vla-object e) 0))))
	       (setq h (trans (apply 'list (mapcar '(lambda (x) (nth x c)) '(0 1 2))) 0 1))
	(command "_.mirror" e "" "_non" h "_non" "@0,1" "_y"))))
  (princ)
Message 4 of 10
skchui6159
Thank you very much!
Message 5 of 10
komondormrex
@skchui6159
or maybe like this
(defun c:mleader_x_mirror ( / mleader_sset index line1)
	(vla-startundomark (vla-get-activedocument (vlax-get-acad-object)))
	(if (setq mleader_sset (ssget "_:l" '((0 . "multileader"))))
    		(repeat (setq index (sslength mleader_sset))
				(setq line1 (vlax-invoke (setq mleader_object (vlax-ename->vla-object (ssname mleader_sset (setq index (1- index))))) 'getleaderlinevertices 0))
				(vl-catch-all-apply 'vla-setdoglegdirection (list mleader_object 1 (vlax-3d-point (mapcar '* '(-1.0 -1.0 1.0) (vlax-invoke mleader_object 'getdoglegdirection 1)))))
				(vlax-invoke mleader_object 'setleaderlinevertices 0 line1)
	(vla-endundomark (vla-get-activedocument (vlax-get-acad-object)))
	(princ)
Message 6 of 10
skchui6159
@komondormrex The lisp is good!, Thanks a lot😁 . But, just interest. How can you find and get the method of object? by vl-dump-obj? The property not show the information of vertex. Where can you find the method? By (vlax-dump-object obj)? I can not see the property value of multileader.
@ВeekeeCZ I want to know trans function. Is the trans(... 0 2) 0 mean UCS, and 2 mean?  Trans Function means from UCS (World) coordinate to integer? Thank you😅
Message 7 of 10
komondormrex
@skchui6159
1. you need to find acadauto.chm reference to the activex and open it.
2. browse to find the object of interest
3. to look at its methods and properties
Message 8 of 10
skchui6159
Thank you very much!😊
Message 9 of 10
ВeekeeCZ
All the HELP system is available online.
https://help.autodesk.com/view/OARX/2025/ENU/
And yes, you can use DUMP func to get a list of methods available for selected object.
(vlax-dump-object (vlax-ename->vla-object (car (entsel))) t)
Also TRANS function is there
https://help.autodesk.com/view/ACD/2025/ENU/?guid=GUID-1A316343-0B68-4DBE-8F49-B4D601CB8FCC
I used (trans pt 0 1) to transform coords for WCS to UCS. Those integers just identifies type of coord systems from - to. The function does THIS type of calculation - it's really a matrix calculation, reals to reals. As precise as possible.
Message 10 of 10
skchui6159
Thank you for your explaination!👍
