Lisp to conver Mleader arrow angle to zero
atawk
Message 1 of 26
atawk
Do you have a lisp that convert the Mleader arrow's "angle" to 180 degree?
Replies (25)
Message 21 of 26
komondormrex
check update in message #14
Message 22 of 26
s05103_jr
Sir, your function is great.
Unluckily, most of my drawings require to work in custom UCS.
I try to get it works with trans function.
(trans pt from to [disp])
However, I always get an error message.
error: bad argument type: 2D/3D point: (172.197 -33.8445 0.0 163.987 -13.5696 0.0)
Can you help?
Message 23 of 26
Sea-Haven
Thats 2 points, (172.197 -33.8445 0.0) (163.987 -13.5696 0.0) did you use VL-get-coordinates ? If so need to make back into a single XYZ point, car cadr caddr.
Message 24 of 26
s05103_jr
No, I don't think I have.
Message 25 of 26
Sea-Haven
You should post code that is definitely 2 points.
Message 26 of 26
komondormrex
that is the list of coordinates of two points. if you want to apply trans  to  first point you need to extract that point coordinates from the list like
(trans (list (car '(172.197 -33.8445 0.0 163.987 -13.5696 0.0)) (cadr '(172.197 -33.8445 0.0 163.987 -13.5696 0.0))) ...)
