Work with text strings
carlos_m_gil_p
carlos_m_gil_p
Hello how are you.
Could you teach me how to do these three things.
I have some folder and file paths and I need to extract some specific things.
File and folder paths may vary.
Case 1
I have a folder path and I want it to return the penultimate folder, in this case "my folder"
(setq path-folder "D:\\folder1\\folder2\\my folder\\txt\\")
"my folder"
Case 2
I have a file path and I want it to return the file name without the extension.
(setq path-file "D:\\folder1\\folder2\\my folder\\txt\\archivo.xxx")
"archivo"
Caso 3
I have a file path and I want it to return the file name with the extension.
(setq path-file-ext "D:\\folder1\\folder2\\my folder\\txt\\archivo.xxx")
"archivo.xxx"
Beforehand thank you very much.
AutoCAD 2026
Visual Studio Code 1.99.3
AutoCAD AutoLISP Extension 1.6.3
Windows 10 (64 bits)
ВeekeeCZ
You need to separate your string by a certain character. That's a very common task and we call it "parsing".
You can try to make your own parser or use eg. THIS Lee's.
The result would be a list...
("D:" "folder1" "folder2" "my folder" "txt" "archivo.xxx")
Also, learn about File-Handling functions, HERE is the list of them. Some functions might streamline your work.
Or... do you want guidance on how to write your own parser? ...it could be simple while loop with some basic string functions...
_gile
You can find many routines to split a string with separator into a list.
Here's one example:
(defun str2lst (str sep / pos)
  (if (setq pos (vl-string-search sep str))
    (cons (substr str 1 pos) (str2lst (substr str (+ (strlen sep) pos 1)) sep))
    (list str)
;; Caso 1
(cadr (reverse (str2lst (vl-string-right-trim "\\" path-folder) "\\")))
;; Caso 2
(vl-filename-base path-file)
;; Caso 3
(last (str2lst path-file-ext "\\"))
Gilles Chanteau
GileCAD
GitHub
sby0531
Hi, below are my codes:
;; return the penultimate folder name
(progn
	path-folder (vl-string-right-trim "\\" path-folder))
  (setq	n 0
	start 0
	acc nil)
  (while (setq pos (vl-string-search "\\" path-folder start))
    (setq acc (cons pos acc)
	  start (1+ pos)))
  (setq pos01 (cadr acc)
	pos02 (car acc))
  (substr path-folder (+ 2 pos01) (- pos02 pos01 1)))
;;return the file name without the extension
(progn
  (vl-filename-base path-file))
;;return the file name with the extension
(progn
  (strcat (vl-filename-base path-file-ext) (vl-filename-extension path-file-ext)))
carlos_m_gil_p
Hi @_gile
As always, a thousand thanks for the help that you have given me to this day.
Thank you.
Excuse my English I only speak Spanish, it is from a translator.
AutoCAD 2026
carlos_m_gil_p
Hi @sby0531
It works well too.
Thanks for your help and everyone on the forum.
AutoCAD 2026
