Lisp to conver Mleader arrow angle to zero
atawk
Message 1 of 26
atawk
Do you have a lisp that convert the Mleader arrow's "angle" to 180 degree?
Replies (25)
Message 2 of 26
ВeekeeCZ
Just thought that I will learn something new.
(vl-load-com)
(defun c:MleaderFlat ( / s i c o)
  (if (setq s (ssget "_:L" '((0 . "MULTILEADER"))))
    (repeat (setq i (sslength s))
      (if (and (setq o (vlax-ename->vla-object (ssname s (setq i (1- i)))))
	       (setq c (vlax-safearray->list (vlax-variant-value (vla-getleaderlinevertices o 0))))
	       (setq c (apply 'list (mapcar '(lambda (x) (nth x c)) '(0 1 2 3 1 5)))))
	(vla-SetLeaderLineVertices o 0 (vlax-safearray-fill (vlax-make-safearray vlax-vbDouble '(0 . 5)) c)))))
  (princ)
Message 3 of 26
Automohan
Please can you modify for 45 degree
"Save Energy"
Did you find this reply helpful? If so please use the Accept as Solution
Message 4 of 26
Automohan
"Save Energy"
Message 5 of 26
devitg
be it can help
Message 6 of 26
Automohan
not asking to create new mleaders, need to edit the existing mleaders
-sorry if i am mistakenly sound- i will try also. . .
"Save Energy"
Message 7 of 26
devitg
@Automohan so please upload a sample dwg , and state constriant to do it .
Better a before and an after .
Message 8 of 26
ВeekeeCZ
(vl-load-com)
(defun c:Mleader45 ( / s i c o h v)
	       (setq h (apply 'list (mapcar '(lambda (x) (nth x c)) '(0 1 2))))
	       (setq v (apply 'list (mapcar '(lambda (x) (nth x c)) '(3 4 5))))
	       (setq h (polar v (* 1.25 pi) (distance h v))))
	(vla-SetLeaderLineVertices o 0 (vlax-safearray-fill (vlax-make-safearray vlax-vbDouble '(0 . 5)) (append h v))))))
  (princ)
Message 9 of 26
Automohan
Wow! That worked beautifully. Thank you. I appreciate the help very much!
"Save Energy"
Message 10 of 26
margono_bersinar
how if we want to make it 30 degrees or 60 degrees , i try change the pi to 0.33 or .66 but that one not accurate. can you help me sir.
Message 11 of 26
ВeekeeCZ
How about 0.333333333333333333, does it help? If that's still not enough, add some more, you can go up to 15 digits.
Message 12 of 26
margono_bersinar
yes sir it can better than before. thank you
i thought we can do with fraction number.
Message 13 of 26
ВeekeeCZ
No, fraction numbers are not supported. You need to use a division. See HERE a list of arithmetical functions that we have available.
Message 14 of 26
komondormrex
This is a function, which takes a decimal degrees angle both positive and negative as an argument. Should be called like (mleader_angle 60) or (mleader_angle -60) etc.
(defun mleader_angle (_angle / mleader_sset index line1 angle_negativity line1_point2)
	(vla-startundomark (vla-get-activedocument (vlax-get-acad-object)))
	(if (not (zerop _angle)) (setq angle_negativity (/ _angle (abs _angle))))
	(if (< 360 (abs _angle))
		(* angle_negativity (setq _angle (- (abs _angle) (* (fix (/ (abs _angle) 360)) 360))))
	(if (minusp _angle)
		(setq _angle (/ (* (- 360 (abs _angle)) pi) 180))
		(setq _angle (/ (* _angle pi) 180))
	(if (setq mleader_sset (ssget "_:L" '((0 . "multileader"))))
    		(repeat (setq index (sslength mleader_sset))
			(setq line1 (vlax-invoke (setq mleader_object (vlax-ename->vla-object (ssname mleader_sset (setq index (1- index))))) 'getleaderlinevertices 0)
			      line1_point2 (polar (list (nth 0 line1) (nth 1 line1))
						  _angle
						  (distance (list (nth 0 line1) (nth 1 line1)) (list (nth 3 line1) (nth 4 line1)))
			(vlax-invoke mleader_object 'setleaderlinevertices 0 (list (nth 0 line1) (nth 1 line1) (nth 2 line1) (car line1_point2) (cadr line1_point2) (nth 2 line1)))
			(if (< (car line1_point2) (car line1))
			  	(progn
					(vl-catch-all-apply 'vla-setdoglegdirection (list mleader_object 0 (vlax-3d-point '(-1.0 0.0 0.0))))
				  	(vl-catch-all-apply 'vla-setdoglegdirection (list mleader_object 1 (vlax-3d-point '(-1.0 0.0 0.0))))
				(progn
					(vl-catch-all-apply 'vla-setdoglegdirection (list mleader_object 0 (vlax-3d-point '(+1.0 0.0 0.0))))
				  	(vl-catch-all-apply 'vla-setdoglegdirection (list mleader_object 1 (vlax-3d-point '(+1.0 0.0 0.0))))
			(princ (strcat "\rMLeaders remain to process: " (itoa index)))
	(vla-endundomark (vla-get-activedocument (vlax-get-acad-object)))
	(princ)
updated
Message 15 of 26
margono_bersinar
how to use this lsp sir?
I copy to my pc can"t use it. can you explain?
Message 16 of 26
komondormrex
as far as i remember
1.  type in in command line (load ''saved_code.lsp") <Enter> -> MLEADER_ANGLE
2. type in in command line eg. (mleader_angle 60) <Enter>
3. select mleaders...
Message 17 of 26
margono_bersinar
when i type "mleader_angle" on command that one "Unknown command "MLEADER_ANGLE". Press F1 for help"
have problem with this lsp?
and can i type command "mleader_angle 60" using space?
Message 18 of 26
komondormrex
it is a function, so it must have parens at both sides "(mleader_angle 60)"
Message 19 of 26
margono_bersinar
ok sir, it's work. thank you
but no simple one to do like LISP in generally sir?
because we always need to copy & paste if we want to use it. use enter after paste the code can't use twice.
Message 20 of 26
margono_bersinar
when i update my autocad to 2021, some mleader in my darwing can't use but other can use this LSP and showing like this "Select objects: ; error: Automation Error. Invalid index". any something reson for this one sir?
