LISP to change the page setup
karfung
karfung
Hi Sir,
 Kindly advise LISP to change the page setup in page setup manager for all the layouts.
Moshe-A
@karfung ,
Explore PlotConfiguration object in VisualLISP ActiveX (this is pagesetup)
also the Layout is consider king of PlotConfiguration you can iterate layouts and make the needed settings.
for specific help, post your code.
Moshe
chriscowgill7373
There are lots of them out there
https://autocadtips1.com/2012/05/18/autolisp-apply-current-page-setup-to-all-layout-tabs/
Here is one. I havent tried this one specifically.   If it doesnt work, I can do a little more research of the routines I have in my library and see if I can get links to those as well.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2026 on Windows 11
karfung
This lisp is not working.
chriscowgill7373
When you load it and run it, is it giving you an error message?  I didnt write it, but I can probably help diagnose it.
Here is another example, complete with a dialog box
https://www.theswamp.org/index.php?topic=12439.msg153420#msg153420
And another
https://www.theswamp.org/index.php?topic=38005.msg430212#msg430212
paullimapa
perhaps you would be interested in running my free app Script Magician which adds the command SMA or SMASSIGN which offers a custom dialog box for you to select an existing page setup to assign to layouts:
Paul Li
IT Specialist
@The Office
Sea-Haven
Just another way around the problem we had in our POP menu various plot options so you just choose the correct printer, and it used a custom lisp that just set the plot parameters. We had a multi storey office so the correct printer near to the user was auto selected. our A0 plotter was on a different floor as well.
If your using PUBLISH then yes need to set up the page parameters. That is another question but yes you can write a DSD file to be used by publish saves again user input.
