Visual LISP, AutoLISP and General Customization
LISP to change a specific attribute from a specific block to a specific value
24 REPLIES 24
Message 1 of 25
28036 Views, 24 Replies
I've had a simple lisp I've been using for years that suddenly disappeared.  It required that you identify a block name, tag name, and the value that you want the tag to be.  All of this is performed via command line, so it is scriptable.  Since I lost it, I've been experimenting with -attedit.  This command comes frustratingly close to what I'm looking for, except it only appends an existing tag, or replaces a specific string within the tag; I can't get it to replace the entire tag, regardless of its value.
1> does anyone have a lisp routine that does what I describe?
or
2> does anyone know how to make -attedit replace a tag value without regard to what the value currently is (like a * wildcard)?
24 REPLIES 24
Message 21 of 25
in reply to: pbejse
Apology. You are right and code is working fine.
Message 22 of 25
in reply to: Hallex
hi
someone can help me with this please?
i tried to mofidy many existing attributes, i want to put every value into ( )
my bloc name is ANCHOR_ANNO and have  6 attributes
GUY1
GUY2
GUY3
GROSSEUR
ANCRE
ECRAT
some attributes are empty and i want to skip those attributes if posssible
thanks a lot
Message 23 of 25
This reply is probably late.
But you can try
(GLBLATTCHG "ANCHOR_ANNO" "GUY1" "TEST")
(GLBLATTCHG "ANCHOR_ANNO" "GUY2" "")
and write a script for it...
Message 24 of 25
Thanks but i finished my lisp already.
Message 25 of 25
in reply to: pbejse
Is it possible to combine this LISP with Width factor of multiline attribute to get a LISP to update the width of specific attribute tag?
(setq s (car (nentsel "\nSelect multiline attribute to change width factor: ")))
(setq x (entget s))
(setq x (subst (cons 41 new_width) (assoc 41 x) x ))
(entmod x)
 (GLBLATTCHG "Rectangle" "Tag3" "NewWidth")
Charlie
AutoCAD Inside the Factory
