I wonder if somebody could help me with a lisp that make a selection of entities by frame ,
like the TRIM option. If we click on the trim option and choose frame, we can click the line that for the trimming , and then to click fence , and click over all the lines we want to trim.
I want the same but with delete option.
In this pic. I clicked on a line that I want the trim to be against it -"cutting line" , but I did it with trim command ,and the broblem is that it doesn't take the lines that starting from the "cutting line" , I want to make the selection from the cutting line with any object , and if I hit the deletion key it will erase only the lines or part of the lines that intersect with the cutting line. See the pic below.
I hope I was clear enough,
Thank you
