@inaamazmi hi,
here is my version.
table scale is controlled by dimscale and the length is in current drawing units.
lines, arcs, plines, splines & arc ellipse all fair game 😀
enjoy
Moshe
(vl-load-com) ; Load ActiveX support
; total curves length
(defun c:tcl (/ collect_data draw_table ; local functions
DIMSCL adoc p0 data^)
(defun collect_data (/ curveLen layName ss elist)
(vlax-for AcDbLayTblRec (vla-get-layers adoc)
(setq curveLen 0 layName (vla-get-name AcDbLayTblRec))
(if (setq ss (ssget "_x" (list (cons '8 layName) '(0 . "line,arc,*polyline,spline,ellipse"))))
(progn
(foreach ename (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
(setq elist (entget ename))
(cond
((and
(wcmatch (cdr (assoc '0 elist)) "ELLIPSE") ; arc ellipse
(not (equal (cdr (assoc '42 elist)) pi 1e-3))
(setq curveLen (+ curveLen (vlax-curve-getDistAtParam ename (vlax-curve-getEndParam ename))))
); case
( t
); cond
); foreach
(setq data^ (cons (cons layName curveLen) data^))
); progn
); if
(vlax-release-object AcDbLayTblRec)
); vlax-for
); collect_data
(defun draw_table (/ modelSpace AcDbTable i)
(setq modelSpace (vla-get-ModelSpace adoc))
(setq AcDbTable (vla-Addtable modelSpace (vlax-3d-point (trans p0 1 0)) (+ (vl-list-length data^) 2) 2 (* DIMSCL 0.4) (* DIMSCL 3.6)))
(vla-setText AcDbTable 0 0 "Schedule Length by Layer")
(vla-setText AcDbTable 1 0 "Layer Name")
(vla-setText AcDbTable 1 1 "Length")
(vla-setColumnWidth AcDbTable 1 (* DIMSCL 1.8))
(setq i 0)
(foreach item (reverse data^)
(setq i (1+ i))
(vla-setText AcDbTable (1+ i) 0 (car item))
(vla-setText AcDbTable (1+ i) 1 (rtos (cdr item) 2 2))
); foreach
(vlax-release-object AcDbTable)
(vlax-release-object modelSpace)
); draw_table
; here start c:tcl
(setq DIMSCL (getvar "dimscale")) ; const
(setq adoc (vla-get-activedocument (vlax-get-acad-object)))
(vla-startUndoMark adoc)
(if (setq p0 (getpoint "\nTable upper left corner: "))
(progn
(collect_data)
(draw_table)
); progn
); if
(vla-endUndoMark adoc)
(vlax-release-object adoc)
(princ)
); c:tcl
