LISP TO CALCULATE LENGTH AND CREATE TABLE BY LAYER
inaamazmi
inaamazmi
Is there a lisp that can calulate the total length of object (arc,polyline,line) in same layer and create a table of layer name and length
Sea-Haven
More than likely, and probably lots of them, did you google it is a very common question.
Moshe-A
@inaamazmi  hi,
here is my version.
table scale is controlled by dimscale and the length is in current drawing units.
lines, arcs, plines, splines & arc ellipse all fair game 😀
enjoy
Moshe
(vl-load-com) ; Load ActiveX support
; total curves length
(defun c:tcl (/ collect_data draw_table ; local functions
	        DIMSCL adoc p0 data^)
 (defun collect_data (/ curveLen layName ss elist)
  (vlax-for AcDbLayTblRec (vla-get-layers adoc)
   (setq curveLen 0 layName (vla-get-name AcDbLayTblRec))
   (if (setq ss (ssget "_x" (list (cons '8 layName) '(0 . "line,arc,*polyline,spline,ellipse"))))
    (progn
     (foreach ename (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
      (setq elist (entget ename))
      (cond
       ((and
          (wcmatch (cdr (assoc '0 elist)) "ELLIPSE")   ; arc ellipse
 	  (not (equal (cdr (assoc '42 elist)) pi 1e-3))
        (setq curveLen (+ curveLen (vlax-curve-getDistAtParam ename (vlax-curve-getEndParam ename))))
       ); case
       ( t
      ); cond
     ); foreach
     (setq data^ (cons (cons layName curveLen) data^))
    ); progn
   ); if
   (vlax-release-object AcDbLayTblRec)
  ); vlax-for
 ); collect_data
 (defun draw_table (/ modelSpace AcDbTable i)
  (setq modelSpace (vla-get-ModelSpace adoc))
  (setq AcDbTable (vla-Addtable modelSpace (vlax-3d-point (trans p0 1 0)) (+ (vl-list-length data^) 2) 2 (* DIMSCL 0.4) (* DIMSCL 3.6)))
  (vla-setText AcDbTable 0 0 "Schedule Length by Layer")
  (vla-setText AcDbTable 1 0 "Layer Name")
  (vla-setText AcDbTable 1 1 "Length")
  (vla-setColumnWidth AcDbTable 1 (* DIMSCL 1.8))
  (setq i 0)
  (foreach item (reverse data^)
   (setq i (1+ i))
   (vla-setText AcDbTable (1+ i) 0 (car item))
   (vla-setText AcDbTable (1+ i) 1 (rtos (cdr item) 2 2))
  ); foreach
  (vlax-release-object AcDbTable)
  (vlax-release-object modelSpace)
 ); draw_table
 ; here start c:tcl
 (setq DIMSCL (getvar "dimscale")) ; const
 (setq adoc (vla-get-activedocument (vlax-get-acad-object)))
 (vla-startUndoMark adoc)
 (if (setq p0 (getpoint "\nTable upper left corner: "))
  (progn
   (collect_data)
   (draw_table)
  ); progn
 ); if
 (vla-endUndoMark adoc)
 (vlax-release-object adoc)
 (princ)
); c:tcl
laz_p_14
Goodmorning,
you can't do a lisp, it can do this in the data field and automatically it refresh the data alwais or with the refresh command.
pschell5S8C8
Can you modify this to have the option to select the layers by name? like when i do "laydel" command, it gives me the option to grab the layers by name if i hit "N" on my keyboard and a dialog opens up, allowing me to make the selection.
