LISP to bump revision numbers, dates and descriptions
11:04 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
The fisrt thing I'm trying to create is a LISP that will modify the REV block in the attached file i.e. if the attribute is already populated with 0 then the lisp will change it to 1, if is already populated with 1 then the lisp will change it to 2 and so on.
The second thing I am trying to create is a LISP that will modify the REVISION block in the attached file by populating the next open revision number, date, initails and revision information.
I think the first thing can be done but I don't know about the second. Ideally both items would be in a lisp file that can be added to a script so I could batch drawings...
my lisp skills are lacking, thanks for any help.
