Message 1 of 10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Good morning all! 🙂
I found this lisp that selects everything that is on selected layers.
It is possible to change it in order to select everything that is on selected layers, based on user selection (instead on drawing model space)?
;;; LayerObjectSelect
;;; Select all objects on selected layers, in current layout
;;; Required Subroutines: AT:ListSelect, AT:TabFilter
;;; Alan J. Thompson, 11.05.09
(defun c:LOS (/ _Layers #List #Filter #SS)
(vl-load-com)
(setq _Layers (lambda (/ d n l)
(while (setq d (tblnext "layer" (null d)))
(and (not (wcmatch (setq n (cdr (assoc 2 d))) "*|*"))
(setq l (cons n l))
) ;_ and
) ;_ while
(vl-sort l '<)
) ;_ lambda
) ;_ setq
(cond
((if dos_multilist
(setq #List (dos_multilist "Select all objects on Layers" "Select layers:" (_Layers)))
(setq #List (AT:ListSelect
"Select layers:"
"30"
"15"
"true"
(_Layers)
) ;_ AT:ListSelect
) ;_ setq
) ;_ if
(setq #Filter "")
(foreach x #List (setq #Filter (strcat #Filter x ",")))
(and (setq #SS (ssget "_X" (list (AT:TabFilter) (cons 8 #Filter))))
(sssetfirst nil #SS)
(print #List)
) ;_ and
) ;_ cond
(princ)
) ;_ defun
;list select dialog
;create a temp DCL multi-select list dialog from provided list
;value is returned in list form, DCL file is deleted when finished
;example: (setq the_list (AT:listselect "This is my list title" "Select items to make a list" "25" "30" "true" (list "object 1" "object 2" "object 3"))
;if mytitle is longer than defined width, the width will be ignored and it will fit to title string
;if mylabel is longer than defined width, mylabel will be truncated
;myheight and mywidth must be strings, not numbers
;mymultiselect must either be "true" or "false" (true for multi, false for single)
;created by: alan thompson, 9.23.08
;some coding borrowed from http://www.jefferypsanders.com (thanks for the DCL examples)
(defun AT:ListSelect ( mytitle ;title for dialog box
mylabel ;label right above list box
myheight ;height of dialog box !!*MUST BE STRING*!!
mywidth ;width of dialog box !!*MUST BE STRING*!!
mymultiselect ;"true" for multiselect, "false" for single select
mylist ;list to display in list box
/ retlist readlist count item savevars fn fo valuestr dcl_id )
(defun saveVars(/ readlist count item)
(setq retList(list))
(setq readlist(get_tile "mylist"))
(setq count 1)
(while (setq item (read readlist))
(setq retlist(append retList (list (nth item myList))))
(while
(and
(/= " " (substr readlist count 1))
(/= "" (substr readlist count 1))
(setq count (1+ count))
(setq readlist (substr readlist count))
);defun
(setq fn (vl-filename-mktemp "" "" ".dcl"))
(setq fo (open fn "w"))
(setq valuestr (strcat "value = \"" mytitle "\";"))
(write-line (strcat "list_select : dialog {
label = \"" mytitle "\";") fo)
(write-line
(strcat " : column {
: row {
: boxed_column {
: list_box {
label =\"" mylabel "\";
key = \"mylist\";
allow_accept = true;
height = " myheight ";
width = " mywidth ";
multiple_select = " mymultiselect ";
fixed_width_font = false;
value = \"0\";
: row {
: boxed_row {
: button {
key = \"accept\";
label = \" Okay \";
is_default = true;
: button {
key = \"cancel\";
label = \" Cancel \";
is_default = false;
is_cancel = true;
}") fo)
(close fo)
(setq dcl_id (load_dialog fn))
(new_dialog "list_select" dcl_id)
(start_list "mylist" 3)
(mapcar 'add_list myList)
(end_list)
(action_tile "cancel" "(setq ddiag 1)(done_dialog)")
(action_tile "accept" "(setq ddiag 2)(saveVars)(done_dialog)")
(start_dialog)
(if (= ddiag 1)
(setq retlist nil)
(unload_dialog dcl_id)
(vl-file-delete fn)
retlist
);defun
(defun AT:TabFilter (/)
;; Tab filter for ssget selection filtering
;; Alan J. Thompson, 06.05.09
(if (eq 1 (getvar 'cvport))
(cons 410 (getvar 'ctab))
(cons 410 "Model")
Thanks 🙂
