LISP ROUTINES / PROGRAMS TO HELP SPEED JOB PROCESS UP
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
I am looking for some input / direction on how I can speed my current work process up. Before I start I want to mention that I have been using autocad for 10 years but I am an engineer NOT a programmer. I have also done my research and have not found exact solutions to my work (if any).
The current process:
First step: I have 100+ air handling units that I import into autocad after I use a software to convert them into individual .dwg files. I have to individually drag and drop each file (100 + times) into the same autocade file, specify basepoint and hit enter twice to place the block. Is there a lisp routine or program that can take my 100+ files and place them in model space evenly spaced out and scaled the same?
Second step: Once all the air handlers are in the dwg I then have to line them up on a line I pull along the bottom of them, which takes forever... Is there a list routine that will allow me to align these blocks easily by setting certain parameters up?
Third step: I have set up a sheet set manager where I can go in and edit multiple sheets at a time because I need to identify what is on each of the air handlers. Then I have to copy my title block with attributes I have set up for the sheet set manager to recognize to a new layout for each air handler. After that I then have to go into each sheet and double click into the viewport to scroll over to the unit I am on and size it appropriately. Is there a lisp routine / program that will make 100+ layouts for me with my title block based on where my blocks are in model space and place the viewport based on block lining?
I have to apply a lot of info into the revision blocks of each sheet. Is there a way I can just make an excel sheet with all the units and changes made to them and import that into sheet set manager?
The third step is the biggest thing I am looking for input on but open to all suggestions on improving my process!
I have attached pics of examples of what I am talking about but let me know if you need something else from me.
Thanks in advance!
