I just stumbled on this, which you might find to be fun...
;; Function created (06-10-02) to convert a complex 2dPolyline
;; (Type 1 = Fit curved, Type 2,3 = Splined)
;; into a Type 0 = Simple
;; while retaining all geometry.
;; Revised (07-06-02) to handle 3D polylines as well.
(defun @cv_simplify (e0 / Object e ent Visible Param Done P Sw Ew Bulge
Vlist Blist Wlist Width Werror 2D)
(cond
((= (type e0) 'VLA-Object)
(setq Object e0 e0 (vlax-vla-object->ename Object))
((= (type e0) 'ENAME)
(setq Object (vlax-ename->vla-object e0))
(setq Visible (vla-get-Visible Object)
Width (vl-catch-all-apply 'vla-get-ConstantWidth (list Object))
Werror (vl-catch-all-error-p Width)
2D (= (vla-get-ObjectName Object) "AcDb2dPolyline")
e e0
(while (not Done)
(and
(setq e (entnext e))
(setq ent (entget e))
(or (= (cdr (assoc 0 ent)) "VERTEX")
(not (setq Done 1))
(/= (logand 16 (cdr (assoc 70 ent))) 16) ; spline control point
(setq P (cdr (assoc 10 ent)))
(setq Vlist (cons P Vlist))
2D
(or
(not Werror)
(setq Sw (cdr (assoc 40 ent))
Ew (cdr (assoc 41 ent))
Wlist (cons (cons Sw Ew) Wlist)
(setq Bulge (cdr (assoc 42 ent)))
(setq Blist (cons Bulge Blist))
(setq Blist (reverse Blist)
Wlist (reverse Wlist)
(if (= Visible :vlax-true)
(vla-put-visible Object :vlax-false)
(vla-put-type Object 0)
(vlax-release-object Object)
(vlax-put Object "Coordinates" (apply 'append (reverse Vlist)))
(setq Param 0)
(repeat (length Blist)
(vla-setbulge Object Param (nth Param Blist))
(and
Werror
(setq Width (nth Param Wlist))
(vla-setwidth Object Param (car Width)(cdr Width))
(setq Param (1+ Param))
(if (not Werror)
(vla-put-ConstantWidth Object Width)
(vla-put-visible Object Visible)
