count block
count block
count block
I have got the count block lsp  thank you everyone. I want it selecting only block name "arc-cp"
"arc-cp" is block name. plz some help
;; helper functions:
;;get indexes and valiues of polyline bulges
(defun get-bulge-list (pline_obj point_list / index bulge_list)
  (setq index 0)
  (while (< index (length point_list))
    (setq bulg      (vla-getbulge pline index)
   bulge_list (cons (list index bulg) bulge_list)
   index      (1+ index)
  (vl-remove-if
    (function (lambda (x) (zerop (cadr x))))
    (reverse bulge_list)
;; groups sublists by number
(defun group-by-num (lst num / ls ret)
  (if (= (rem (length lst) num) 0)
    (progn
      (setq ls nil)
      (repeat (/ (length lst) num)
 (repeat num
   (setq ls
      (cons (car lst) ls)
  lst (cdr lst)
 (setq ret (append ret (list (reverse ls)))
       ls  nil
  ret
;; divide list by number
(defun divplus (len segm / num lst)
  (setq num (fix (/ len segm)))
  (setq cnt 0)
  (while (<= cnt num)
    (setq tmp (* cnt segm))
    (setq lst (append lst (list tmp)))
    (setq cnt (1+ cnt))
  (setq delta (- len (last lst)))
  (if (/= delta 0.)
    (setq lst (append lst (list (+ (last lst) delta))))
    lst
;; divide parameter by number
(defun divparam (param num / cnt diff div_list div_lst end tmp)
  (setq end  (1+ param)
 diff (/ param num 1.0)
 cnt  1
  (while (< tmp (- end diff))
    (setq tmp   (+ param (* cnt diff))
   div_lst (cons tmp div_lst)
   cnt   (1+ cnt)
  (reverse div_lst)
;; get list of point defined by list of parameters
(defun pnt-by-param (obj param_list /)
  (mapcar (function (lambda (x)
        (vlax-curve-getpointatparam obj x)
   param_list
;; create safearray of points
(defun safe-points (lst / pt_list points)
  (setq pt_list (apply 'append lst))
  (setq points (vlax-safearray-fill
   (vlax-make-safearray
     vlax-vbdouble
     (cons 0 (1- (length pt_list)))
   pt_list
;; error handler
(defun div-error (msg)
  (if
    (vl-position
      msg
      '("console break"
 "Function cancelled"
 "quit / exit abort"
     (princ "Error!")
     (princ msg)
  (while (> (getvar "cmdactive") 0) (command))
  (command "._undo" "_end")
  (command "._u")
  (setq *error* olderror)
  (princ)
(vl-load-com);load ActiveX
(prompt "\n *** Type WP to execute *** \n")
;;   MAIN PROGRAM    ;;
(defun C:wp (/        *error*  acsp    adoc      appd
      bulge_list   coor    coors     div-error
      new_pline olderror  param_list      pline
      quant     ss  tmp    util      wp-filt
  (or adoc
      (setq adoc
      (vla-get-activedocument
        (vlax-get-acad-object)
  (or appd (setq appd (vla-get-application adoc)));no needs in this prgm
  (or acsp
      (setq acsp
      (vla-get-block
        (vla-get-activelayout adoc)
  (or util (setq util (vla-get-utility adoc)))
  (command "._undo" "_mark")
  (setq olderror *error*)
  (setq *error* div-error)
  (setq pline (vlax-ename->vla-object (car (entsel "Select polyline"))))
  (setq coors (vlax-get pline 'Coordinates)
 coors (cond ((= (rem (length coor) 2) 0)
       (group-by-num coors 2)
      ((= (rem (length coor) 3) 0)
       (group-by-num coors 3)
      (T nil)
 coors (mapcar (function (lambda (x) (trans x 0 1))) coors)
  (setq bulge_list (get-bulge-list pline coors))
  (setq param_list nil)
  (foreach p bulge_list
    (setq tmp      (divparam (caar bulge_list) 36);change number by suit
   param_list (append tmp param_list)
   bulge_list (cdr bulge_list)
  (setq wp-filt
  (vl-sort (append coors (pnt-by-param pline param_list))
    (function (lambda (a1 a2)
         (< (vlax-curve-getdistatpoint pline a1)
     (vlax-curve-getdistatpoint pline a2)
  (setq new_pline (vla-addpolyline acsp (safe-points wp-filt)))
  (vlax-put-property new_pline 'Closed :vlax-true)
      (T nil)
;;;(setq ss (ssget "_WP" coors));for debug only
  (setq ss (ssget "_WP" coors (list (cons 0 "INSERT"))))
  ;; < ** PUT YOUR FUNCTION HERE ** >
  ;; i.e. quantity of objects within polyline
  ;;TesT:
  (setq quant (vla-get-count
  (vla-get-activeselectionset adoc)
  )        ;end of TesT
  (alert
    (strcat "There are: " (itoa quant) "\n blocks selected")
  (vla-delete new_pline)
        (if (not (vlax-object-released-p x))
   (vlax-release-object x)
   (list pline new_pline)
 div-error nil
  (princ)
;;Test (C:wp)
;;(princ)
Ranjit_Singh
I am not at my computer so cannot test. But try changing this
to
(setq ss (ssget "_WP" coors (list (cons 0 "INSERT") (cons 2 "arc-cp"))))
it's good working thank you...
