Visual LISP, AutoLISP and General Customization
Lisp programming in AutoCAD
7 REPLIES 7
Message 1 of 8
eric_adumekwe
476 Views, 7 Replies
Sent by you:
Good morning, please is it normal for my AutoCAD 2025 not to recognize the let, loop, dotimes, when, collect and dolist functions when coding using the lisp programming language ? if no, how can i solve this problem ? Thank you
7 REPLIES 7
Message 2 of 8
pbejse
in reply to: eric_adumekwe
@eric_adumekwe wrote:
Sent by you:
Curious, has it work for you in lower version  of AutoCAD?  Otherwise use the equivalent in AutoLisp namely while , foreach, mapcar and repeat
Message 3 of 8
those are common lisp functions most likely, while autocad supports autolisp which is a bit different.
Message 4 of 8
eric_adumekwe
in reply to: pbejse
Hi, i am new to lisp programming so i started with AutoCAD 2025. I don't think the while , foreachmapcar and repeat functions are the exact substitutes
Message 5 of 8
Hi, can i configure AutoCAD 2025 to recognize common lisp functions ?
Message 6 of 8
pbejse
I'm sure its not the exact equivalent but we can write a subfunction to emulate those functions.
Tell us what you need to do.
Message 7 of 8
nope
Message 8 of 8
paullimapa
Good discussion here on Common Lisp vs Autolisp
Paul Li
IT Specialist
@The Office
AutoCAD Inside the Factory
