LISP - Move center text to selected line/polyline segment and then align text to it and distance text from line given a distance value
cool.stuff
cool.stuff
Hello 🙂
Does anyone have a lisp to move a selected mtext from its center and align and move it to selected line/polyline segment and distance selected text from selected line/polyline given a defined value?
Many many thanks 🙂
Sea-Haven
Post a sample dwg with before and after.
cool.stuff
Thanks for the answer @Sea-Haven 🙂
Sample dwg attached
Sea-Haven
Try this
; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-move-center-text-to-selected-line-polyline-segment-and-then/td-p/13328372
(defun c:txt2line ( / mp ang txt ins mp)
(defun getplineseg ( / elst ename pt param preparam postparam pt1 pt2)
  (setq elst (entsel "\nSelect pline segment: "))
  (setq ename (car elst))
  (setq pt (cadr elst))
  (setq pt (vlax-curve-getClosestPointTo ename pt))
  (setq param (vlax-curve-getParamAtPoint ename pt))
  (setq preparam (fix param))
  (setq postparam (1+ preparam))
  (setq pt1 (vlax-curve-getPointAtParam ename preparam)
    pt2 (vlax-curve-getPointAtParam ename postparam))
  (setq mp (setq mp (mapcar '* (mapcar '+ pt1 pt2) '(0.5 0.5))))
  (setq ang (angle pt1 pt2))
(setq oldsnap (getvar 'osmode))
(setvar 'osmode 0)
(setq dist 0.1)
(getplineseg)
(setq txt (car (entsel "\nPick text ")))
(setq ins (cdr (assoc 10 (entget txt))))
(setq mp (polar mp (- ang (/ pi 2)) dist))
(command "move" txt "" ins mp)
(princ)
cool.stuff
Works like a charm 🙂 many thanks again for helping in another problem @Sea-Haven
