Lisp - Insert block and match scale to another block
Hi there,
Need a little help,
I require a LISP that will insert a new block and that new blocks scale matches the x,y,z scale of a block that will already be in the drawing.
A little help will be greatly appreciated.
Thanks You
Matt
Ajilal.Vijayan
Hi Matt,
Welcome to this forum.
Try with this one
(defun c:mtchblk (/ mblk mx my mz);command name MTCHBLK
(setq mblk (entget (car (entsel "Select the Block to match :"))))
(setq
mx (cdr (assoc 41 mblk))
my (cdr (assoc 42 mblk))
mz (cdr (assoc 43 mblk))
);setq
(command "-insert" "myblock" "x" mx "y" my "z" mz PAUSE 0)
(princ)
);defun
