New HatchPatterns, RasterImages, OLEs to Back; Select ... to send them back
I wonder if there is possible, write two lisps:
1. All newly done Hatch Patterns, Raster Images, OLEs have the DrawOrder --> Back option.
2. Select Hatch Patterns, Raster Images, OLEs to change their DrawOrder to "Back".
I know, that there is a command HATCHTOBACK, which means "Send all the Hatch Patterns from entire drawing to back"
, but I want to have lisp for "Send ONLY SELECTED, NOT ALL Hatch Patterns to back".
I know about "HPDRAWORDER" command.
Here I found similar topic and an user made macro. But I prefer lisp.
http://www.theswamp.org/index.php?topic=10593.0
What do you know about it?
This lisp would be work like this:
Select all OLE Objects (QSELECT --> OLE Objects --> All) and then DrawOrder --> Under Objects, to send them under Lines and the Lines will be apparent (visible).
But the problem is, in this way I can't use the QSELECT command in lisp.
