Select all Polilines in Entire Drawing - but QSELECT is in DialogBox
Message 1 of 19
I wonder if it is possible to write a lisp "Select all Polilines in Entire Drawing" (there is second option: not "in Entire Drawing", but "In current Selection").
I tried, but QSELECT command is displayed only in the DialogBox. And there is no "-QSELECT" command (commands with "-" on the beginning are opened in an Interactive Menu, even if in lisp code before them is (INITDIA).)
Could you tell me: Is that possible to do this lisp?
Replies (18)
Message 2 of 19
Kent1Cooper
Here's a way to select all of them in the drawing:
(sssetfirst nil (ssget "_X" '((0 . "*POLYLINE"))))
And to select all of them from among the current selection:
(sssetfirst nil (ssget "_I" '((0 . "*POLYLINE"))))
Kent Cooper, AIA
Message 3 of 19
Thank you.
Could you please explain me what are these letters meaning?
sssetfirst - Sets which objects are selected and gripped
nil - means "nothing"
(sssetfirst gripset [pickset])
gripset
Type: nil
AutoCAD no longer supports grips on unselected objects, so this argument is ignored. However, if gripset is nil and no pickset is specified, sssetfirst turns off the grip handles and selections it previously turned on.
pickset
But what mean "_X", "_I", etc.?
Message 4 of 19
Message 5 of 19
Finally I write good lisp, using your advice.
(defun c:SCTQ (/)
 (princ "\nFor this while you can select only Polylines: ")
 (sssetfirst nil (ssget '((0 . "*POLYLINE"))))
(defun c:SCTAQ (/)
 (princ "\nAll Polylines are selected.")
I have a few questions:
1. what to type for what kind of AutoCad Objects?
I know, hat I can write "CIRCLE", "LINE", but what to type for Rotated dimension, Aligned Dimension (they are available to choose in DialogBox of QSELECT command)
2. I want also to write third type of lisp: "Select all kind of Objects apart from Polylines: ".
How to write it? What expressions to use?
3.  Why these lisps written by me don't work?
(defun c:SCTQ1 (/)
 (princ "\nFor this while you can select only Lines:")
 (setq SelectLines
  (ssget
   '((0 . "LINE"))
(defun c:SCTAQ1 (/)
 (princ "\nAll Lines are selected.")
 (setq AllLines
  (ssget "X"
   '((0 . "LINE"))
I think I used right expressions. But there are errors. Here are prompts from CommandLine:
Command: SCTAQ1
; error: too few arguments
Command: SCTQ1
Select objects: 0 found
Select objects: 0 found, 0 total
 When using SCTQ1, I click but I can't select nothing. Why?
Message 6 of 19
Lee_Mac
I'm pleased to see that you found my ssget function reference useful!
The filter list supplied to the ssget function determines the entities which are included in the selection by matching the DXF groups/logical operators found in the filter list against the corresponding DXF data held by each entity in a graphical selection or in the drawing database of the active drawing.
A reference for this DXF data can be found here.
Since string-valued DXF groups found in the ssget filter list are matched using the same criteria as the wcmatch function, you can include wildcard operators, such as the "~" (tilde) operator to match everything except the given pattern:
(ssget "_X" '((0 . "~*POLYLINE")))
Alternatively, you can use the NOT logical operator, e.g.:
(ssget "_X" '((-4 . "<NOT") (0 . "*POLYLINE") (-4 . "NOT>")))
Your code looks correct to me - perhaps you have a different definition of the function loaded?
Message 7 of 19
I don't kno what's going on...
Here we have the lisps, I described them.
What is the most wrong thing: These lisps should have effect only on Lines.
So is for only one of these lisps. The others either are broken (they have errors)
or have effect for both Lines and Polylines.
If you don't believe, try it for yourself.
; on ground of idea of Lee_Mac
;Selects not only Lines, but Lines and Polylines.
(defun c:SCTAQ (/)
 (sssetfirst nil
  (ssget "_X"
  '((0 . "*LINE"))
; Doesn't select not only Lines, but Lines and Polylines.
; SCTA`Qa = SeleCT All Non-Lines (method 'a')
(defun c:SCTA`Qa (/)
 (princ "\nAll Non-Lines (Objects which are not Lines) are selected.")
 (sssetfirst nil
  (ssget "_X"
  '((0 . "~*LINE"))
(defun c:SCTA`Qb (/)
 (sssetfirst nil
  (ssget "_X"
  '((-4 . "<NOT") (0 . "*LINE") (-4 . "NOT>"))
(defun c:SCTTQ (/)
 (princ "\nFor this while you can select only Lines: ")
 (sssetfirst nil
  (ssget
  '((0 . "*LINE"))
(defun c:SCTT`Qa (/)
 (princ "\nFor this while you can select All apart from Lines: ")
 (sssetfirst nil
  (ssget
  '((0 . "~*LINE"))
(defun c:SCTT`Qb (/)
 (sssetfirst nil
 '((-4 . "<NOT")
   (0 . "*POLYLINE")
   (-4 . "NOT>")
; You can select as well Lines as Non-Lines.
;Command:  SCTTA`QB
;For this while you can select All apart from Lines: ; error: bad argument type:
;lselsetp ((-4 . "<NOT") (0 . "*POLYLINE") (-4 . "NOT>"))
; idea of DW
; Is loaded, but doesn't give the effect
;Selects nothing
(defun c:SCTAQ1 (/ AllLinesSelected)
 (setq AllLinesSelected
  (ssget "X"
   '((0 . "LINE"))
(defun c:SCTA`Q1a (/ AllNon-LinesSelected)
 (setq AllNon-LinesSelected
  (ssget "X"
   '((0 . "~LINE"))
(defun c:SCTA`Q1b (/ AllNon-LinesSelected)
  (ssget "X"
; works very good
; Selects Lines, but not Polylines, Arcs
(defun c:SCTTQ1
 (/ SelectOnlyLines)
 (setq SelectOnlyLines
  (ssget
   '((0 . "LINE"))
; works very good
; Selects Polylines, Arcs, but not Lines
(defun c:SCTT`Q1a
 (/ SelectApartFromLines)
 (setq SelectApartFromLines
  (ssget
   '((0 . "~LINE"))
(defun c:SCTT`Q1b
  (ssget
Message 8 of 19
Lee_Mac
Try the following variations -
in my experience it is sometimes necessary to clear any active selection (as noted in the code):
; Includes Lines/Polylines/XLines/Splines
(defun c:SCTAQ ( )
    (sssetfirst nil nil) ;; clear any active selection
    (sssetfirst nil (ssget "_X" '((0 . "*LINE"))))
; Excludes Lines/Polylines/XLines/Splines
(defun c:SCTA`Qa ( )
    (sssetfirst nil (ssget "_X" '((0 . "~*LINE"))))
(defun c:SCTA`Qb ( )
    (sssetfirst nil (ssget "_X" '((-4 . ""))))
; Includes Lines/Polylines/XLines/Splines (MANUAL SELECTION)
(defun c:SCTTQ ( )
    (sssetfirst nil (ssget '((0 . "*LINE"))))
; Excludes Lines/Polylines/XLines/Splines (MANUAL SELECTION)
(defun c:SCTT`Qa ( )
    (sssetfirst nil (ssget '((0 . "~*LINE"))))
(defun c:SCTT`Qb ( )
    (sssetfirst nil (ssget '((-4 . ""))))
What program/editor are you using to write your code?
Message 9 of 19
I use standard Notepad from Windows.
Message 10 of 19
Lee_Mac
I thought so - using standard Notepad makes it incredibly difficult to spot obvious errors such as missed parentheses or typos.
I would strongly recommend writing your code using either the Visual LISP IDE (VLIDE) provided with AutoCAD, or a similar code editor (such as Notepad++).
Where the VLIDE is concerned, here are a few tutorials to get you started:
The Visual LISP Editor - Part 1
The Visual LISP Editor - Part 2
An Introduction to the Visual LISP IDE
Retrieving Information About a Function
A Shortcut to Localising Variables
Debugging Code with the Visual LISP IDE
Message 11 of 19
Kent1Cooper
I didn't dig too deep, but I did notice one thing you should be careful of:
(defun c:SCTAQ (/)
  (sssetfirst nil
    (ssget "_X"
      '((0 . "*LINE"))
Be aware that the above will find not only Lines and Polylines, but also SPLINEs and XLINEs and MULTILINEs.  If you want only Lines and Polylines, try:
      '((0 . "LINE,*POLYLINE"))
The same kind of potential overlap may apply to certain other entity types, too.
Kent Cooper, AIA
Message 12 of 19
Now I undarstand the difference between "LINE" and "*LINE".
"LINE" is simply set of Lines. ANd the '*' symbol before 'LINE' represents 'anything from alphabet staying before 'Line'', so we get *=Multi (or simply M), *=Poly, *=X. Thank you for this great notice.
Message 13 of 19
Spoiler
My friend uses Notepad ++ and he recommended me it one year ago. I thought about it at this time one year ago, but I haven't used it so far. And I think I will finally download and use it. Thank you for good advice.
Message 14 of 19
Lee_Mac
Since strings within the ssget filter list may be matched using the same operators as the wcmatch function, you may find it useful to read the documentation for this function.
Message 15 of 19
Lee_Mac
Notepad++ is indeed a fantastic general code editor - I use it for everything except AutoLISP & DCL as in my opinion, the VLIDE is the most suitable editor for writing AutoLISP, since, although quite dated, the IDE provides an AutoLISP debugger (among other utilities) which can be invaluable for finding problems with your code, as I describe in the tutorial linked earlier.
Lee
Message 16 of 19
Lee,
I have this lisps written in two ways:
1st - that is your way, with 'sssetfirst'
2nd - it is my idea. I use local Variables and 'setq'
Here we go:
; 1st way
;OK
(defun c:SCTAL (/)
 (princ "\nAll *Lines are selected.")
 (sssetfirst nil
  (ssget "_X"
  '((0 . "*LINE"))
; OK
; SCTA`La = SeleCT All Non-_Lines (method 'a')
(defun c:SCTA`La (/)
 (princ "\nAll Non-*Lines (Objects which are not *Lines) are selected.")
 (sssetfirst nil
  (ssget "_X"
  '((0 . "~*LINE"))
; OK
(defun c:SCTA`Lb (/)
 (princ "\nAll Non-Lines (Objects which are not *Lines) are selected.")
 (sssetfirst nil
  (ssget "_X"
;OK
(defun c:SCTTL (/)
 (princ "\nFor this while you can select only *Lines: ")
 (sssetfirst nil
  (ssget
  '((0 . "*LINE"))
; OK
(defun c:SCTT`La (/)
 (princ "\nFor this while you can select All apart from *Lines: ")
 (sssetfirst nil
  (ssget
  '((0 . "~*LINE"))
; OK
(defun c:SCTT`Lb (/)
 (sssetfirst nil
  (ssget
;2nd way
; idea of DW
;Selects nothing
;From CommandLine:
;Command: SCTAL1
;All *Lines are selected.<Selection set: 8f4>
(defun c:SCTAL1 (/ All_LinesSelected)
 (setq All_LinesSelected
  (ssget "_X"
  '((0 . "*LINE"))
;Selects nothing
;From CommandLine:
;Command: SCTA`L1A
;All Non-*Lines (Objects which are not *Lines) are selected.<Selection set: 89e>
(defun c:SCTA`L1a (/ AllNon-_LinesSelected)
 (setq AllNon-_LinesSelected
  (ssget "_X"
  '((0 . "~*LINE"))
;Selects nothing
;From CommandLine:
;Command: SCTA`L1B
;All Non-*Lines (Objects which are not *Lines) are selected.<Selection set: 923>
(defun c:SCTA`L1b (/ AllNon-_LinesSelected)
  (ssget "_X"
; OK
(defun c:SCTTL1
 (/ SelectOnly_Lines)
 (setq SelectOnly_Lines
  (ssget
   '((0 . "*LINE"))
; OK
(defun c:SCTT`L1a
 (/ SelectApartFrom_Lines)
 (setq SelectApartFrom_Lines
  (ssget
   '((0 . "~*LINE"))
; OK
(defun c:SCTT`L1b
  (ssget
All of lisps written using 1st method work properly.
But three of lisps written by the 2nd method are loaded without error, but they don't give any effect.
Could you please explain me why these three lisps don't work properly?
Message 17 of 19
"The Visual LISP Editor - Part 1
The Visual LISP Editor - Part 2"
Afralisp... It is a great site for people who just begin with lisp.
Message 18 of 19
Lee_Mac
The ssget function will attempt to retrieve a selection set using a method determined by the supplied arguments, and if successful, will return this selection set (which your code then assigns to a local variable) - the ssget function does not highlight or grip the selection returned.
The sssetfirst function accepts one or two selection sets as arguments and will hightlight and/or grip all objects in the supplied selection sets.
I would suggest reading the documentation for each of these functions so that you become familiar with the arguments, returns & behaviour of each function.
Lee
Message 19 of 19
hencoop
Damian,
Another good reason to use VLIDE is that you can highlight a function, right-click on it and open the apropos widow which provides a direct link to help on the function (as well as other functions containing the highlighted string).
AutoCAD User since 1989. Civil Engineering Professional since 1983
Product Version: 13.6.1963.0 Civil 3D 2024.4.1 Update Built on: U.202.0.0 AutoCAD 2024.1.6
                        27.0.37.14 Autodesk AutoCAD Map 3D 2024.0.1
                        8.6.52.0 AutoCAD Architecture 2024
