Lisp for selecting all hatches type solid and generating boundary for them.
Message 1 of 8
Could somebody help me with this simple routine:
1. Select all hatches with pattern SOLID
2. Generate boundary for them (_.hatchgenerateboundary)
3. Change the colour of this boundary to green.
Thanks!
Replies (7)
Message 2 of 8
(defun c:R2 ( / ss en ht hs)
(if (setq ss (ssget "_X" '((0 . "HATCH") (2 . "SOLID"))))
(command "_.hatchgenerateboundary" ss ""))
(princ)
Message 3 of 8
ВeekeeCZ
(princ)
Almost done...
(defun c:R2 ( / ss)
	     "_.chprop" ss "" "_C" 3 ""))
    (princ)
Message 4 of 8
Thank you for your help again.
Maybe I didn't express myself clearly, but I wanted to change the colour of the line to green, not the colour of the SOLID 🙂
And one more thing, can we add a third condition for the selection - 1) HATCH, 2) PATTERN "SOLID", 3) COLOUR "CYAN"
Message 5 of 8
ВeekeeCZ
What layer to use?
hatchgenerateboundary creates a boundary in current layer...
Color cyan assigned to object only, or to a layer of hatch (color by layer)?
Message 6 of 8
Layer name "Reinforcement" (existing layer), but with colour of the boundary - green.
Layer CYAN to be in the selection criteria.
(if (setq ss (ssget "_X" '((0 . "HATCH") (2 . "SOLID") ?(COLOUR "CYAN"))))
Message 7 of 8
ВeekeeCZ
Ok... try this. Because of layer I has to go thru selections set.
(defun c:R2 ( / *error* nVAR oVAR adoc ss en)
  (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break,end"))
      (princ (strcat "\nError: " errmsg)))
    (mapcar 'setvar nVAR oVAR)
    (vla-endundomark adoc)
    (princ))
  (vla-startundomark (setq adoc (vla-get-activedocument (vlax-get-acad-object))))
  (setq oVAR (mapcar 'getvar (setq nVAR '(CMDECHO CECOLOR))))
  (mapcar 'setvar nVAR '(0 "3"))
  (if (setq ss (ssget "_X" '((0 . "HATCH") (2 . "SOLID") (62 . 4))))
    (repeat (setq i (sslength ss))
      (setq en (ssname ss (setq i (1- i))))
      (command "_.HATCHGENERATEBOUNDARY" en ""
	       "_.CHPROP" "_L" "" "_LA" (cdr (assoc 8 (entget en))) "")))
  (*error* "end")
Message 8 of 8
* Nevermind 🙂
