Lisp for scrolling through open drawings
Has anyone a lisp to scroll through drawing files?
I frequently have multiple drawing open simultaneously & would like to use buttons instead of Ctrl+Tab
My idea is to create two buttons on a toolbar with arrows
I would like it to work similarly to Ctrl+Tab / Shift Ctrl+Tab
Maybe even a 'First' & 'Last function (I realise this would need four buttons)
AutoCAD 2014 & 15 have drawing tabs for open drawing files.  These are pretty effecient for flipping between drawings.  Maybe someone listening here can talk more about AcadXTabs Drawing tabs application.  This is somethign that I have used since AutoCAD 2002.  I don't know if it works without a liscense.  Tony have not been around for a while.
this might help.
http://forums.autodesk.com/t5/autocad-2010-2011-2012/acadxtabs-amp-tony-tanzillo/td-p/2743863
Matthew
hmsilva
Hi sbanister,
add this four (quickly written and not fully tested) functions to your acaddoc.lsp file, to ensure that are loaded in every opened dwg.
(vl-load-com)
(defun nextdwg (/ docs i index n)
  (or acad* (setq acad* (vlax-get-acad-object)))
  (or acdoc (setq acdoc (vla-get-activedocument acad*)))
  (or doc (setq doc (vla-get-name acdoc)))
  (setq docs (vla-get-documents acad*))
  (setq n (vla-get-count docs))
  (if (> n 1)
    (progn
      (setq i 0)
      (repeat n
        (if (= (vla-get-name (vla-item docs i)) doc)
          (setq index i)
        (setq i (1+ i))
      (if (<= (1+ index) (1- n))
        (vla-activate (vla-item docs (1+ index)))
        (vla-activate (vla-item docs 0))
  (princ)
(defun prevdwg (/ docs i index n)
  (if (> n 1)
    (progn
      (setq i 0)
      (repeat n
          (setq index i)
        (setq i (1+ i))
      (if (minusp (1- index))
        (vla-activate (vla-item docs (1- n)))
        (vla-activate (vla-item docs (1- index)))
  (princ)
(defun lastdwg (/ docs n)
  (if (> n 1)
  (princ)
(defun firstdwg (/ docs n)
  (if (> n 1)
  (princ)
and the buttons command string are
(nextdwg)
(prevdwg)
(lastdwg)
(firstdwg)
Hope this helps,
Henrique
It works very well indeed Henrique. Thank you.
Rather than alter the acaddoc file (which is hidden on my machine) I saved the lisp as Scrolldwgs.lsp & within the macro wrote:
^C^C(load "SCROLLDWGS") (nextdwg)
All the functions can be called this way
hmsilva
You're welcome, sbanister!
Glad I could help
Henrique
