ASD - Reactor interrups.
Hi all,
i have a "close" reactor in AUTOCAD 2015. Works fine. Now i m trying ASD but i got a interrup.
Code is below, If i check the interrup he stops at alert 2 , don't alert 3, and sits in a loop or something like that after alert 2. i can break it with a escape but with ASD i get a popup for close then.
1 ->>>> So we can either way try to "unload that reactor" or
2 ->>>> try to adjust that reactor to ASD ways. maybe change the part between alert 2-3 (that's the hard part because i really have no idea why he stops). Instead of AUTOCAD the close Command of ASD is always with a pop-updialog (do you want to save changes) even if you save just before close. Also Filedia has no effect on that dialog.
3 ->>>> or maybe a thirt option is to override or make a second close command and try to build it myself. without pop up. maybe i can import the one from AUTOCAD and set as second? Not sure if it's possible.
Any thoughts on this would be handy, so fire away :D. as far as my knowledge go, reactors isn't a part of it.
Command: *Cancel* Command: *Cancel* Command: _close ; entering keyboard break loop ; entering keyboard break loop Automatic save to C:\Users\dieter.bevernage\appdata\local\temp\5107_Noir Fontaine Hall 2_Kolommen2(test)_1_1_3053.sv$ ... Command:
;;======================================================================= ;; CLOSE reactor Tony Tanzillo + Edit:text function Dieter Bevernage ;;======================================================================= (vl-load-com) (defun smart-command-reactor (commands StartCallback EndCallback / ended) (vl-load-reactors) (setq ended (vlr-command-reactor nil '( (:vlr-commandEnded . internal-commandEnded) (:vlr-commandCancelled . internal-commandEnded) (:vlr-commandFailed . internal-commandEnded) ) ) ) (vlr-remove ended) (vlr-command-reactor (list ended StartCallback EndCallback (if (listp commands) (mapcar 'strcase commands) (list (strcase commands)) ) ) '((:vlr-commandWillStart . internal-commandWillStart)) ) ) ;;======================================================================= (defun internal-commandWillStart (reactor args / data result) (setq data (vlr-data reactor)) (if (and (member (car args) (last data)) (setq result (apply (cadr data) (list (car args)))) ) (progn (vlr-data-set (car data) (list (caddr data) result) ) (vlr-add (car data)) ) ) ) ;;======================================================================= (defun internal-commandEnded (reactor args / data) (setq data (vlr-data reactor)) (vlr-remove reactor) (apply (car data) (list reactor (vlr-current-reaction-name) (car args) (cadr data) ) ) ) ;;======================================================================= (if *my-smart-close-reactor* (vlr-remove *my-smart-close-reactor*)) ;;======================================================================= (setq *my-smart-close-reactor* (smart-command-reactor ;; command(s) as list '("CLOSE") ;; StartCallback (called when CLOSE starts) (function (lambda (cmdname) ;;;=================================================== ;;; *** from here ;;;=================================================== ;;; (vla-ZoomExtents (vlax-get-acad-object)) (setq Listtxt nil) (setq Newlist nil) (setq Removelist nil) (setq OldList nil) (setq DWGprefix (getvar "dwgprefix") Externfolder (strcat DWGprefix "\\#Library-Do Not Edit#") Localfolder (strcat "C:\\Autodesk-library") DWGprefixL (strlen DWGprefix) Last4letters (substr DWGprefix (- DWGprefixL 4) 4) DWGname (getvar "dwgname") DWGnameL (strlen DWGname) DWGname (substr DWGname 1 (- DWGnameL 4)) BlockUsed (strcat Externfolder "\\BinTitleBlock.txt") TxtForDwgTitleblock (strcat Externfolder "\\Bin"DWGname"Titleblock.txt") project (strcat Externfolder "\\BinProjectBlock.txt") Activedoc (vla-get-activedocument (vlax-get-acad-object))) (if (not(vl-file-directory-p Localfolder)) (vl-mkdir Localfolder) ) (if (vl-file-directory-p Externfolder) (if (eq Last4letters "ACAD") (progn (if (not (open project "R")) (progn (if(not(setq dcl_id (load_dialog "PROJECTNUMBER.dcl"))) (progn (alert "The DCL file could not be loaded!") (exit) );PROGN (progn ;;;--- Load the definition inside the DCL file (if (not(new_dialog "PROJECTNUMBER" dcl_id)) (progn (alert "The DOSSIER definition could not be loaded!") (exit) );PROGN (progn (action_tile "DOSSIERNUMMER" "(setq Projectnumber $value)") (start_dialog) (unload_dialog dcl_id) (setq file (open project "W")) (write-line (strcat Projectnumber) file) (close file) ) ) ) ) ) (progn (setq file (open project "R")) (setq Projectnumber (read-line file)) (close file) ) ) (ALERT "1") (if (open TxtForDwgTitleblock "r") (progn; first argument 1.1.1 (setq file (open TxtForDwgTitleblock "R")) (while (setq Txtline (read-line file)) (setq Listtxt (cons Txtline Listtxt))) (close file) (setq Listtxt (reverse Listtxt)) ) (setq Listtxt nil) ) (Alert "2") (if (not(eq Listtxt nil)) (progn (foreach x Listtxt (setq ListX x) (if (and (not (eq (tblsearch "block" ListX) nil)) (ssget "_X" '((0 . "INSERT")(66 . 1))) ) (vlax-for block (vla-get-ActiveSelectionSet Activedoc) (if (= (strcase (vlax-get-property block 'EffectiveName)) (strcase ListX));;;;;;;Maybe it ;;;;;;;;;;;;;;has to do with this? (progn (setq Newlist (cons ListX Newlist)) );Progn ) ) ) ) ) ) (ALERT "3") (foreach x Listtxt (setq ListtxtX x) (if (not(member ListtxtX Newlist)) (setq Removelist (cons ListtxtX Removelist)) ) ) (setq file (open TxtForDwgTitleblock "W")) (close file) (setq Start (vl-string-search (strcat "\\" "\\") (strcat TxtForDwgTitleblock))) (if (not (eq Newlist nil)) (progn (setq Newlist (Reverse Newlist)) (foreach x Newlist (setq file (open TxtForDwgTitleblock "A")) (write-line (strcat x) file) (close file) ) ) ) (if (not (eq Removelist nil)) (progn (if (open BlockUsed "R") (progn (setq file (open BlockUsed "R")) (while (setq Txtline (read-line file)) (setq OldList (cons Txtline OldList))) (close file) (setq OldList (reverse OldList)) (setq file (open BlockUsed "W")) (foreach x OldList (setq OldListX x) (if (vl-position OldListX Removelist) (progn (Alert (strcat "You deleted block " OldListX ", This has been removed from the settings.")) (vlax-for y (vla-get-blocks Activedoc) (if (and (= (vla-get-objectname y) "AcDbBlockTableRecord") (= (strcase (vla-get-name y)) (strcase x)) ) (vla-delete y) ) ) ) (progn (write-line (strcat OldListX) file) ) );if );foreach (close file) );progn ) ) ) );progn ) ) (setq Listtxt nil) (setq Newlist nil) (setq Removelist nil) (setq OldList nil) ;;; (alert "Command CLOSE was issued.") ;;;=================================================== ;;; *** to here ;;;=================================================== ) ) ;; EndCallback (called when CLOSE ends) (function (lambda (data) (setvars data) (sssetfirst nil) (setq app nil adoc nil) ) ) ) ) ;;======================================================================= (defun setvars (data) (mapcar (function (lambda (v / r) (setq r (getvar (car v))) (setvar (car v) (cdr v)) (cons (car v) r) ) ) data ) ) ;;======================================================================= (princ "\nCLOSE reactor enabled.") ;;======================================================================= (princ) ;;=======================================================================
............... LOG Trace stack ............... <1> :KBD-BREAK <2> :TOP-COMMAND <3> :KBD-BREAK <4> :TOP-COMMAND <5> :KBD-BREAK [6] (VLAX-FOR ...) [7] (FOREACH ...) [8] (#<USUBR @000000004cf4e3e0 -lambda-> "CLOSE") [9] (APPLY (quote #<USUBR @000000004cf4e3e0 -lambda->) ("CLOSE")) [10] (INTERNAL-COMMANDWILLSTART #<VLR-Command-Reactor> ("CLOSE")) <11> :CALLBACK-ENTRY <12> :REACTOR-CALLBACK ............... ...............
