ASD - Reactor interrups.
Hi all,
i have a "close" reactor in AUTOCAD 2015. Works fine. Now i m trying ASD but i got a interrup.
Code is below, If i check the interrup he stops at alert 2 , don't alert 3,  and  sits in a loop or something like that after alert 2. i can break it with a escape but with ASD i get a popup for close then.
1 ->>>>  So we can either way try to "unload that reactor" or
2 ->>>>  try to adjust that reactor to ASD ways. maybe change the part between alert 2-3 (that's the hard part because i really have no idea why he stops). Instead of AUTOCAD the close Command of ASD is always with a pop-updialog (do you want to save changes) even if you save just before close. Also Filedia has no effect on that dialog.
3 ->>>>   or maybe a thirt option is to override or make a second close command and try to build it myself. without pop up. maybe i can import the one from AUTOCAD and set as second? Not sure if it's possible.
Any thoughts on this would be handy, so fire away :D. as far as my knowledge go, reactors isn't a part of it.
Command: *Cancel*
Command: *Cancel*
Command: _close ; entering keyboard break loop
Automatic save to C:\Users\dieter.bevernage\appdata\local\temp\5107_Noir Fontaine Hall 2_Kolommen2(test)_1_1_3053.sv$ ...
Command:
;; CLOSE reactor Tony Tanzillo + Edit:text function Dieter Bevernage
(vl-load-com)
(defun smart-command-reactor (commands StartCallback EndCallback / ended)
  (vl-load-reactors)
  (setq ended
    (vlr-command-reactor nil
        (:vlr-commandEnded . internal-commandEnded)
        (:vlr-commandCancelled . internal-commandEnded)
        (:vlr-commandFailed . internal-commandEnded)
  (vlr-remove ended)
    (list
      ended
      StartCallback
      EndCallback
      (if (listp commands)
        (mapcar 'strcase commands)
        (list (strcase commands))
    '((:vlr-commandWillStart . internal-commandWillStart))
(defun internal-commandWillStart (reactor args / data result)
  (setq data (vlr-data reactor))
  (if
    (and
      (member (car args) (last data))
      (setq result (apply (cadr data) (list (car args))))
    (progn
      (vlr-data-set
        (car data)
        (list (caddr data) result)
      (vlr-add (car data))
(defun internal-commandEnded (reactor args / data)
  (vlr-remove reactor)
  (apply
    (car data)
    (list
      reactor
      (vlr-current-reaction-name)
      (car args)
      (cadr data)
(if *my-smart-close-reactor* (vlr-remove *my-smart-close-reactor*))
(setq *my-smart-close-reactor*
  (smart-command-reactor
    ;; command(s) as list
    '("CLOSE")
    ;; StartCallback (called when CLOSE starts)
    (function
      (lambda (cmdname)
        ;;; *** from here
;;;        (vla-ZoomExtents (vlax-get-acad-object))
	(setq Listtxt nil)
	(setq Newlist nil)
	(setq Removelist nil)
	(setq OldList nil)
	(setq DWGprefix (getvar "dwgprefix")
	      Externfolder (strcat DWGprefix "\\#Library-Do Not Edit#")
	      Localfolder (strcat "C:\\Autodesk-library")
	      DWGprefixL (strlen DWGprefix)
	      Last4letters (substr DWGprefix (- DWGprefixL 4) 4)
	      DWGname (getvar "dwgname")
	      DWGnameL (strlen DWGname)
	      DWGname (substr DWGname 1 (- DWGnameL 4))
	      BlockUsed (strcat Externfolder "\\BinTitleBlock.txt")
	      TxtForDwgTitleblock (strcat Externfolder "\\Bin"DWGname"Titleblock.txt")
	      project (strcat Externfolder "\\BinProjectBlock.txt")
	      Activedoc (vla-get-activedocument (vlax-get-acad-object)))
	(if (not(vl-file-directory-p Localfolder))
	    (vl-mkdir Localfolder)
	(if
	  (vl-file-directory-p Externfolder)
	  (if (eq Last4letters "ACAD")
	    (progn
	    (if (not (open project "R"))
	      (progn
		(if(not(setq dcl_id (load_dialog "PROJECTNUMBER.dcl")))
		  (progn
		    (alert "The DCL file could not be loaded!")
		    (exit)
		    );PROGN
		  (progn
		    ;;;--- Load the definition inside the DCL file
		    (if (not(new_dialog "PROJECTNUMBER" dcl_id))
		      (progn
			(alert "The DOSSIER definition could not be loaded!")
			(exit)
			);PROGN
		      (progn
			(action_tile "DOSSIERNUMMER" "(setq Projectnumber $value)")
			(start_dialog)
			(unload_dialog dcl_id)
			(setq file (open project "W"))
			(write-line (strcat Projectnumber) file)
			(close file)
	      (progn
		(setq file (open project "R"))
		(setq Projectnumber (read-line file))
		(close file)
	    (ALERT "1")
	    (if
	      (open TxtForDwgTitleblock "r")
	      (progn; first argument 1.1.1
		(setq file (open TxtForDwgTitleblock "R"))
		(while (setq Txtline (read-line file))
		  (setq Listtxt (cons Txtline Listtxt)))
		(close file)
		(setq Listtxt (reverse Listtxt))
	      (setq Listtxt nil)
	    (Alert "2")
	    (if
	      (not(eq Listtxt nil))
	      (progn
		(foreach x Listtxt
		  (setq ListX x)
		  (if (and
			(not (eq (tblsearch "block" ListX) nil))
			(ssget "_X" '((0 . "INSERT")(66  . 1)))
		    (vlax-for block (vla-get-ActiveSelectionSet Activedoc)
		      (if
			(= (strcase (vlax-get-property block 'EffectiveName)) (strcase  ListX));;;;;;;Maybe it ;;;;;;;;;;;;;;has to do with this?
			(progn
			  (setq Newlist (cons ListX Newlist))
			  );Progn
	    (ALERT "3")
	    (foreach x Listtxt
	      (setq ListtxtX x)
	      (if (not(member ListtxtX Newlist))
		(setq Removelist (cons ListtxtX Removelist))
	    (setq file (open TxtForDwgTitleblock "W"))
	    (close file)
	    (setq Start (vl-string-search (strcat "\\" "\\") (strcat TxtForDwgTitleblock)))
	    (if (not (eq Newlist nil))
	      (progn
		(setq Newlist (Reverse Newlist))
		(foreach x Newlist
		  (setq file (open TxtForDwgTitleblock "A"))
		  (write-line (strcat x) file)
		  (close file)
	    (if (not (eq Removelist nil))
	      (progn
		(if
		  (open BlockUsed "R")
		  (progn
		    (setq file (open BlockUsed "R"))
		      (setq OldList (cons Txtline OldList)))
		    (close file)
		    (setq OldList (reverse OldList))
		    (setq file (open BlockUsed "W"))
		    (foreach x OldList
		      (setq OldListX x)
		      (if (vl-position OldListX Removelist)
			(progn
			  (Alert (strcat "You deleted block " OldListX ", This has been removed from the settings."))
			  (vlax-for y (vla-get-blocks Activedoc)
			    (if (and (= (vla-get-objectname y) "AcDbBlockTableRecord")
				     (= (strcase (vla-get-name y)) (strcase x))
			      (vla-delete y)
			(progn
			  (write-line (strcat OldListX) file)
			);if
		      );foreach
		    (close file)
		    );progn
	    );progn
	  (setq Listtxt nil)
	  (setq Newlist nil)
	  (setq OldList nil)
;;;        (alert "Command CLOSE was issued.")
        ;;; *** to here
    ;; EndCallback (called when CLOSE ends)
    (function
      (lambda (data)
        (setvars data)
        (sssetfirst nil)
        (setq app nil adoc nil)
(defun setvars (data)
  (mapcar
    (function
      (lambda (v / r)
        (setq r (getvar (car v)))
        (setvar (car v) (cdr v))
        (cons (car v) r)
    data
(princ "\nCLOSE reactor enabled.")
(princ)
LOG Trace stack
<1> :KBD-BREAK
<2> :TOP-COMMAND
<3> :KBD-BREAK
<4> :TOP-COMMAND
<5> :KBD-BREAK
[6] (VLAX-FOR ...)
[7] (FOREACH ...)
[8] (#<USUBR @000000004cf4e3e0 -lambda-> "CLOSE")
[9] (APPLY (quote #<USUBR @000000004cf4e3e0 -lambda->) ("CLOSE"))
[10] (INTERNAL-COMMANDWILLSTART #<VLR-Command-Reactor> ("CLOSE"))
<11> :CALLBACK-ENTRY
<12> :REACTOR-CALLBACK
Although, if i recall,
3->>>> ASD is a structural program with is adding elements, so that means, if we change the close command, (there must be a reason why they changed the close command) , that we maybe lose intelligence of those objects. so i can conclude that overwriting the close command maybe harm ASD-ways.
So only option 2 and 1 is available.
I m now gonna test option 1 by deleting the reactor and see if i can get something else running.
any thoughts on option 2 would be welcome.
hmsilva
Hi Dieter,
I do not deal with reactors for a long time, but if I remember correctly, we can't use 'ssget' inside a reactor call-back from ':vlr-commandWillStart'...
Try to use only the Layouts Collection and Blocks Collection to search for Blocks with Attributes, and add to the 'Newlist' the 'EffectiveName' property.
i.e.
(vlax-for layt (vla-get-layouts Activedoc)
  (vlax-for blk (vla-get-block layt)
    (if
      (and (= (vla-get-objectname blk) "AcDbBlockReference")
           (= (vla-get-hasattributes blk) :vlax-true)
                         blk
                         (if (vlax-property-available-p blk 'EffectiveName)
                           'EffectiveName
                           'Name
              (strcase ListX)
Hope this helps,
Henrique
