vlisp for adding to support file search path
Message 1 of 17
This adds the folder C:\TEMP1 to my support file search path (SFSP). However if I later use the same code to add a different folder such as C:\TEMP2, the first folder I added gets removed. How do I append to my current folders in SFSP  and not replace any folder previously added.
;Load the VLisp support
(vl-load-com)
;Store a reference to the Application Object
(setq acadObject (vlax-get-acad-object))
;Store a reference to the Preferences Object
(setq prefsObject (vlax-get-property acadObject 'Preferences))
;Store a reference to the Files Object
(setq tabnameObject (vlax-get-property prefsObject 'Files))
;Get the Support Path
(setq thePath (vlax-get-property tabnameObject 'SupportPath))
;add your new path to the existing path variable
(setq thePath (strcat thePath ";" "C:\\TEMP1"))
(vlax-put-property tabnameObject 'SupportPath thePath)
Replies (16)
Message 2 of 17
redtransitconsultants
This is what I use for add in support paths... just pay attention to the last lines as those are where you add in your paths. They need to be numbered 0, 1, 2, ... etc. Blue is your path and red is the number... (addSupportPath "C:\\My\\Path1" 0)
(defun addSupportPath (dir pos / tmp c lst)
   (setq tmp ""
         c -1
   (if
      (not
        (member (strcase dir)
         (setq lst
           (mapcar 'strcase
            (parse (getenv "ACAD") ";")
         );setq
        );member
      );not
   (progn
      (if (not pos)
         (setq tmp (strcat (getenv "ACAD") ";" dir))
         (mapcar '(lambda (x)
         (setq tmp (if (= (setq c (1+ c)) pos)
               (strcat tmp ";" dir ";" x)
               (strcat tmp ";" x)
      lst
   (setenv "ACAD" tmp)
(princ)
);end defun
(defun parse (str delim / lst pos)
   (setq pos (vl-string-search delim str))
   (while pos
      (setq lst (cons (substr str 1 pos) lst)
         str (substr str (+ pos 2))
   (if (> (strlen str) 0)
      (setq lst (cons str lst))
      (reverse lst)
);end defun
(addSupportPath "C:\\My\\Path2" 1)
(addSupportPath "C:\\My\\Path3" 2)
Steve Hill,Civil Designer / .NET Developer / AutoCAD and AutoCAD Civil 3D Certified Professional
http://redtransitconsultants.com/
Autodesk Exchange Store
Twitter | LinkedIn | YouTube
Message 3 of 17
Thanks for the input. Still not quite what I am looking for. I could not get the paths to add below what I already have (have 10 paths now which includes the defaults), only on top using 0,1, etc. Also, putting added paths on top causes AutoCAD to become unstable and it will crash when trying to save workspace. I want to use a seperate support path lisp with each loader of the menus (located in different folders) that will "append" the existing list and add to bottom of list, and as a result, each seperately added path will need to be added last to the SFSP list no matter how many existing paths are listed. I don't want to globally add all of the paths or load the menus. I'd also rather not control with profiles. My approach may not be the best method, or feasible, and perhaps I will need to persue other method for our office CAD staff to choose which menus to load.
Message 4 of 17
hmsilva
(vl-load-com)
Hi mishman,
to add or to remove a path from Support File Search Paths, try this Lee Mac's Add & Remove Support File Search Paths functions.
Hope this helps,
Henrique
Message 5 of 17
I'm running this for 80 some users and have for quite a while. I haven't seen any unstable issues regarding the order of the search paths.
I suppose you could do a count on the number of paths though and have it increment the numbers of where it's placing the paths so they are at the end. You could modify my code to do that pretty easily I think.
Message 6 of 17
You most likely will not experience any stability issues unless your users utilize workspaces. I have experienced that if you have non-default support paths at the top of the list then try to create or save a workspace your session of AutoCAD will crash. I am going to take a look at Lee-Mac's function sand give that a try based on recommendation from hmsilva.
Message 7 of 17
jpCADconsulting
This one has been working for me for a long while (all glory to Lee MAC!).
Puts them at the end of the list.
Note: No backslashes if you want to add just the root drive letter.
(defun AddSupportPath (dir / Cpath Uname) ;http://lee-mac.com/addremovesupportpaths.html
  (setq Cpath (getenv "ACAD") Uname (getenv "Username") dir (vl-string-subst Uname "%Username%" dir))
  (or (vl-string-search dir Cpath) (setenv "ACAD" (strcat Cpath ";" dir)))
  (princ)
(AddSupportPath "R:")
(AddSupportPath "R:\\Slides")
(AddSupportPath "R:\\Fonts")
(AddSupportPath "R:\\Patterns")
Message 8 of 17
c3dsolutions
After adding the support file paths, though they appear in the list, but AutoCAD/Civil 3D does not recognize them until I open the Options window and click OK. The same problem happens when adding the printer style support paths (PrinterStyleSheetDir) but nobody knows why: (setenv "PrinterStyleSheetDir") Not applying?
Any idea how to force feed the file paths?
Message 9 of 17
john.uhden
The new paths probably also have to be added to TrustedPaths in the same manner.
John F. Uhden
Message 10 of 17
c3dsolutions
Sounds good, does not work. 😄
Message 11 of 17
john.uhden
When I said "in the same manner" I meant generally.
You can't use the same exact code you were provided.
But you can try this function.
You provide it a list of paths, as in
(setq paths (list "C:\\Mystuff" "H:\\Custom" "G:\\Add-Ons"))
Then run the function...
(AddTrusted paths)
Here's the function
(defun AddTrusted (newpaths / Old New)
  (vl-load-com)
  (setq Old (getvar "TrustedPaths") New Old)
  (foreach path newpaths
    (if (vl-file-directory-p path)
      (setq New (strcat New ";" path))
      (alert (strcat "Directory " path " does not exist."))
  (if (/= New Old)(setvar "TrustedPaths" New))
It will warn you if any of the paths is not found.
It could be more embellished to check if the path is already trusted, but that's up to you to check existing conditions.
I really don't know if it makes any difference, but I'm not going to experiment on my office PC.
John F. Uhden
Message 12 of 17
c3dsolutions
John,
Of course, I did not use the same code. I can add the file paths to all lists (trusted paths, working file support paths and printer support file paths) using separate lisps, but the file paths are somehow not recognised until I open the Options window and click Ok. I.e.: I want to plot something after adding the plot style table search file path, but the ctb file is marked as missing. I open the Options window and without changing anything I close with Ok. I go back to plot, and the ctb is there. This is just frustrating.
Message 13 of 17
c3dsolutions
Just in case I will give a try to your code to see whether it resolves the issue.
Message 14 of 17
john.uhden
@c3dsolutions
I recall that sometimes the changes you make programmatically don't become effective until you restart AutoCAD.
See if that is the case for you.
John F. Uhden
Message 15 of 17
Sea-Haven
John is on the money a few different things are read on start up and not changed during a session. If you edit a custom mnu you will not see changes till you do a menuload, did this for multiple users only 1 cuix saved on server changes made were seen on next user startup.
Not sure if reinit will help
Message 16 of 17
c3dsolutions
Silly Me!
The solution was to write the file paths in one line:
(list path "\\filepath\\numberone\\;\\filepath\\numbertwo")
instead of:
After this change the file paths get recognised.
Message 17 of 17
john.uhden
@c3dsolutions
That may be the case for the support file paths, but the trusted function I gave you wants the paths as a list, not a long string.  That's because it verifies each path existence.
John F. Uhden
