Lisp for PDF Import, Save As
ryan_carey
ryan_carey
Can someone please help me out with a LISP file or write a script for this to happen?  I have tried everything I know.
With AutoCAD open, I would like to do this
File
New
(When the select Template box opens, I have to change my “look in” location. I would love to *in the lisp file* paste the location of .dwt file in where I want it to get it from)
The template opens in layout so I want to switch to model tab
Insert
PDF import
Go to the folder of the PDF’s (here there is a list of 100 PDFs and they are not rasterized.  I have tested them and they import as entities, editable lines,etc)
I would like for it to take all the PDF’s in that folder and convert them to DWG and save as an individual file for each.  If needed, I can combine all PDF’s into one file and save it as its own pdf document.
If that’s not feasible, do you know of a way of taking a set of PDF’s that are able to import to a dwg file and saveas dwg?
I have tried some of the software’s online and they seem to not convert as well as doing the PDF import function.
I have thousands of PDF’s that I need to import into DWG and save as their individual files.
ryan_carey
If that doesnt make sense, how about to simplify it.. Can someone please help me with a LISP to do this:
With a drawing open in model space, i would like to
-right click on layout 1
-click "from Template"
-here i would like to insert my template location  (ex: Y:\AutoCAD Support\Blocks & Templates\New Drawing Templates\D size.dwt)
-Open
-"OK" when it prompts me for Layout 1
-delete layout1 and layout2 (so my titleblock will be the only layout tab)
-zoom extents inside the titleblocks viewport
-click out of viewport
-zoom extents
-save
-close
Repeat with the next file in that folder
